rw7810's Avatar
resurface Flywheel
I seem to remember that there is a "right" way and wrong way to resujrface a porsche flywheel. Can anyone please enlighten me??
Robert Williams
70' 911T
Old 06-13-2003, 07:14 AM
rw7810's Avatar
It's a 225 mm for a 2.2
Robert Williams
70' 911T
Old 06-13-2003, 09:15 AM
Author of "101 Projects"
Wayne 962's Avatar
If memory serves me correctly, you need to resurface both the top and bottom and have them be exactly a certain distance apart, otherwise the pressure plate will not work correctly. Our shop (EMS) knows how to do this - I just give the flywheels to them...
-Wayne
Old 06-13-2003, 09:17 AM
wayne, you're thinking about the 69 and earlier wheels. the 70 up are just one surface. the outer edge of the cut can't have any bevel to speak of, so the p/plate can seat properly, so a diamond stone needs to be used. a diamond stone keeps a sharp edge, unlike a softer stone which will round off quickly. but they are about $250, so call around, as not everyone uses one.
206 637 4071
Old 06-13-2003, 10:09 AM
If I could add to John's comments. The cutter tool for flywheels, as well as for brake rotors, should be a grinding stone (diamond or otherwise). A typical tool-steel cutter is not hard enough to cut through work-hardened metal (created by hot-spots), and it will skip over the surface and dull the cutting edge.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 06-13-2003, 12:28 PM
Banned
snowman's Avatar
Sherwood,
What about carbide cutters?
Old 06-13-2003, 09:16 PM
Carbide cutter? Hmmm. I'd say if the material has hard spots in it, go with a grinding stone. It also provides a nice even finish without increasing the rotation speed of the workpiece. What's your analysis?
Sherwood
Old 06-13-2003, 10:02 PM
Banned
snowman's Avatar
Only thing I have heard is that if you have hard spots, ie dark spots, your flywheel, pressure plate, or brake rotor is history. In other words, it can be machined, but it will never wear properly.
Old 06-15-2003, 09:58 PM
