ARP Head Studs
Hello Everyone,
I am rebuilding a 3.2L engine and using ARP head studs. I read that the studs should just be "hand tight" into the case. Is this correct?
Old 10-18-2023, 09:28 AM
as long as they thread into the case freely. otherwise I would carefully spin them in.
In reality the factory studs have a depth setting and since i use factory studs thats what I tend to do.
1976 914
1986 951
Old 10-18-2023, 10:59 AM
It's a 914 ...
stownsen914's Avatar
I'd guess they don't recommend butting the stud hard against the base of the threads in the case, which some might otherwise be inclined to. That could compromise on the case threads.
Old 10-18-2023, 01:28 PM
Ah, what about installed height. It seems that should govern how far in. How is bottoming the stud in the hole compromising anything? If you take a stud out of a hole, the same thead stud should go in if the threads are clean. I have not installed my ARP’s yet, and will check out the top thread dimension rather the dome end the ARP’s have.
Old 10-18-2023, 04:47 PM
Installed height doesn’t matter as much with arps because you’re using a nut. Installed height of I think 13.5 ish for stock studs is so you can get an Allen wrench on the barrel nut.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 10-21-2023, 05:04 AM
Jeff Alton's Avatar
Installed Height still matters with ARP as the nut end is not threaded all the way to the tip, there is a bullet nose there. So, use the correct installed height to ensure proper thread engagement with the nut.
Cheers
www.turn3autosport.com
Old 10-21-2023, 03:28 PM
If one was to compare the lengths, I would bet the ARP bolts are longer. The bullet tip would add to the overall length. The bullet tip aides in installing the nut.
Cheers
Old 10-21-2023, 06:57 PM
Jeff Alton's Avatar
Yes, but you need to be aware of the length up to the top thread regardless.... The installed height is set to that. You can install a little "tall" and still access the nut, but if you install a little "short" you *may* not engage all the threads.
At any rate, it takes a few more seconds per stud install to do it "right"....
Cheers
Old 10-21-2023, 07:25 PM
This is a question I get asked a lot.
In another post about Head studs, I mentioned we added features to our studs that make them easier to use. We listened to what others were asking.
We added the upper hex so the stud length can be changed when the heads are installed. If there is not enough or too much thread engagement for the head nut, the nut can be loosened and the stud turned to obtain more or less.
This eliminates the need to measure the installed height before fitting other parts.
Old 10-22-2023, 07:33 AM
Cheers
Your right, I should have mentioned that you still want to get them close to stock specs.
Old 10-22-2023, 11:02 AM
Thanks Everyone.
I've installed them per the ARP heights. Just seems odd such an important piece isn't torqued to some degree.
Old 10-23-2023, 12:03 PM
It's a 914 ...
The point of torquing something is to put tension on it. For a head stud, that happens when you torque the nut at the other end.
Old 10-23-2023, 02:41 PM
