Fuel hardline connection type size
When I put in the EFI on my SC earlier this year, I didn't have the right size connectors to securely connect to the factory hard lines so I just re-used sections of the old line.
It's the end of the driving season, so time to clean this shortcut up. Can anyone tell me what size/type these connectors are? I'd like to find them to build my own new fuel line or find an AN adapter.
'82 SC non-original...with '86 Carrera interior...aero mirrors...968 roof antenna...JWest shifter...CR eletrocooler, alternator and fuse panel...RHD/Xfaktory ITBs...Bosch cops...EMU Black ecu...Adapt Motorsports crank/cam sensor, crank pulley...M1 cams...Achtungkraft GTK exhaust https://www.instagram.com/mango_911sc/ |
fittings
I believe that these should work for you......
![]() regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Thanks Al.
