JoeMag's Avatar
What is this stuff on case vent?
Came by this pic of a motor and noticed several things connected to the case vent. Any idea what these items might be? I get the throttle actuation bar, but not the item below it or the thing that has rubber coupler to case vent tube.
Old 11-07-2023, 01:45 PM
PCA Member since 1988
That's weird. The thing on the case vent tube looks like an anti drain-back valve, but if so, it belongs on the return oil hose under the engine. Maybe some kind of PCV setup?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-07-2023, 02:20 PM
The check valve is likely the check valve used on GT3's to build up 10 in Hg of crankcase vacuum.
The thing under the bellcrank looks like a fuel pressure regulator.
The thing with the six hoses going to it is likely a vacuum manifold to get a stronger signal for the MAP sensor when running ITB's.
No idea what the check valve with the blue top is for, unless it's going to the brake booster.
Old 11-07-2023, 02:56 PM
JoeMag's Avatar
Thanks Dan... Is this the case check valve? Do you know if it's just a check valve or regulator to 10in vacuum?
Old 11-08-2023, 07:27 AM
That's it. It has a spring in it that regulates the crankcase vacuum to 10 in Hg. BUT, do some research on the rear main seal problems and the updates.
In nascar we would run way more crankcase vacuum than 10 in Hg but ran the seals backward so that they would hold the vacuum. Obviously if the dry sump wouldn't pull the vacuum, or blowby went high, it would leak oil like crazy. Later on seals were made that had double lip seals and would hold the oil in under vacuum and pressure.
And looking at the 6 hose manifold again, it looks like it might go to the brake booster. Still dunno about the check valve with the blue top.
Old 11-08-2023, 09:25 AM
JoeMag's Avatar
yea, I've read some update posts on GT3 rear seal issues. Sounds like the last version of air-cooled seal is preferred with the spacer update.
My guess on the blue check valve is for the vacuum canister when using resonance flap (ala: cup intake on top of throttles).
Can you run case vacuum at that level on aircooled motor? ...I'd assume GT3 oil pump will pull it down.
Old 11-08-2023, 10:45 AM
No reason why it wouldn't work on an air cooled. I know that because of the blowby, it won't work on turbo cars. Not that it will stop functioning, but that the crankcase will never get there under boost.
Old 11-08-2023, 11:10 AM
targa72e's Avatar
Blue check valve looks like its small for a vacuum hose. Maybe it goes to a vacuum reservoir used to trigger resonance chamber valves. Not uncomment to put resonance intake over ITB's.
https://rasantproducts.com/pages/intake-system-faq
john
Old 11-08-2023, 02:23 PM
al lkosmal's Avatar
The item below the throttle bar looks like a fuel pressure regulator.
RGruppe #669
http://www.x-faktory.com/
Old 11-09-2023, 09:06 AM
