Life Cycles of Case Thru Bolts
Anyone have a feeling about the number of life cycles in a OEM Bolt at proper torque. I bet the factory had a guesstimate.
PCA Member since 1988
Many more than you will rebuild the engine!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Fleabit peanut monkey
It's not a stretch bolt. It's fine. I would replace the o-rings if you have it apart.
1981 911SC Targa |
Thread Tools | |
Rate This Thread | |
