JLN JLN is offline
911sc 3.0 1979
Hi 👍
My 3.0 engine is out and I need new camshafts. Want a bit more performance.
964 camshafts or maybe DC13 camshafts from Dougherty Racing Camshafts would they be ok ?
Will the car still be good to drive as my daily car in the summer ? 😊
Old 12-31-2023, 03:10 AM
Senior Member
Originally Posted by JLN View Post
Hi 👍
Depends, are you keeping motor stock?
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 12-31-2023, 07:08 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Hi 👍
Back in the mid 70s Harry Weber took a clean sheet of paper and designed a camshaft that was perfectly suited to the Porsche CIS engine. What he came up with was the 20/21. I haven't found a better camshaft for the stock CIS engine yet.
I this John calls his version the DC19 or DC21?.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-31-2023, 07:42 AM
JLN JLN is offline
The rest of my engine seems to be ok. But I need new camshafts 👍
Old 12-31-2023, 09:58 AM
New cams
My understanding is you should at least recondition rockers not a tech but I stayed at Holiday inn express.
Henry does those exchange…..l
TOT
Old 12-31-2023, 12:24 PM
The 9 Store
It’s always ok until you open it up - lol.
All used parts sold as is.
Old 12-31-2023, 12:30 PM
PCA Member since 1988
I haven’t used the 20/21 cam that Henry references. I do use the Knight Racing M1 cam with CIS. I know from my own measurements and testing that the M1 cam uses as much lift and duration as possible without the valve contacting the pistons. The CIS/Carrera pistons limit lift and duration, so I’m nearly certain that the 20/21 numbers are very close to the M1 numbers.
If you plan to keep your current pistons, call William Knight and talk to him about the M1. 615-969-4917. If you change your pistons to ones with valve cutouts, you can choose a “hotter” cam.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-01-2024, 12:30 AM
JLN JLN is offline
I live in Norway 👍 What do you mean by "Henry does those exchange"
Old 01-01-2024, 12:46 AM
It means that he would have a set to send to you already reconditioned and he would take your old rockers and refurbish them for his next customer.
Old 01-01-2024, 09:12 PM
JLN JLN is offline
Originally Posted by porschedude996 View Post
it means that he would have a set to send to you already reconditioned and he would take your old rockers and refurbish them for his next customer.
Old 01-02-2024, 01:07 PM
