Case seam damage
So I have some damage on the seam about 6 inches near the bottom oil pump cover.
its on the outer edge of the seam.. Raised up about less than 1mm. It appears its from people jacking up the car from the engine.
1. Do I get a flat metal block with sandpaper and just sand the edge down on both cases... If so what grit sand paper? should i also block the entire case with sand paper as well?
or
Do i leaven it alone?....thinking even though the seam got dented, both sides of the case dented together which would make me think they would fit back in together.?
thanks
Old 01-18-2024, 06:29 PM
I’m having difficulty visualizing from the description. I think a picture might help. Is the case apart? The mating surface must be flat.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-18-2024, 06:43 PM
Or do I hammer it smooth .?
.both halves have it. so If one side is up, the the other side of the case must be bent down since it probally happened with the case bolted from a jack. Just on the edge. Which has me wondering do I leave it alone and it will fit back like a puzzle. ?
Old 01-18-2024, 07:14 PM
I would leave it alone as you’ll likely do more damage.
I would reassemble and seal with threebond, yamabond, because of the sealing qualities of the sealant and the thickness of the sealant would forgive the damage.
Bruce
Old 01-19-2024, 04:00 AM
safe's Avatar
Remove raised highspots. Sealer might fix scratches and lowspots, but high spots are not good.
A fine file and light pressure. A file is a marvelous tool, on a flat surface it does almost nothing, any raised part it will remove.
What kind of case? A mag case would most likely need machine work in other places.
Magnus
Old 01-19-2024, 07:14 AM
I wouldn't trust your punch as a straightedge
Old 01-19-2024, 08:33 AM
File the high spots off on both sides, and as others have mentioned, Yamabond, RPV or similar sealant you'll be fine. Don't use the factory Loctite sealant.
'77 1973 911RS Backdate, 2.7 liter w/webers
'70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress
'75 911 RSR street car in progress
'77 930 Replica '75 993 GT2 EVO race car , 3.6 TT
'79 928 5 speed money pit in progress
Old 01-19-2024, 09:06 AM
Yeah use a straight edge.
Old 02-08-2024, 08:15 PM
