Parts Help
My memory retention was way better when I was young. I could disassemble a motorcycle engine/transmission and recall every shim, washer ect. But apparently not any more.
HELP! Where do these go?
Old 02-27-2024, 02:19 PM
PCA Member since 1988
Those are the air deflector vanes that were riveted to the cone that goes on the back (front actually) of the alternator. Why did you remove them?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-27-2024, 02:21 PM
Thanks Pete, I pulled them to powder coat. I also removed the one on the underside of the fiberglass fan shroud.
Old 02-27-2024, 02:53 PM
Ya know, no one else is ever gonna see those.
Old 02-27-2024, 02:56 PM
Ah yes, like this…
Old 02-27-2024, 03:30 PM
I know… it’s just going to keep me up at night. Haaah
Old 02-27-2024, 04:25 PM
He was giving me the look when I wasn’t going to disassemble and powder coat.
Old 02-27-2024, 04:29 PM
Senior Member
The mice will.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 02-28-2024, 06:39 AM
Ouch! That hurt Dpmulvan. I guess I’ll put a mouse trap in there. There is plenty of room. There is a Cat under the car. I’m feeling more confident there will not be a problem.
Originally Posted by Dpmulvan View Post
The mice will.
Old 02-28-2024, 10:45 AM
