Parts Help
My memory retention was way better when I was young. I could disassemble a motorcycle engine/transmission and recall every shim, washer ect. But apparently not any more.
HELP! Where do these go? ![]()
PCA Member since 1988
Those are the air deflector vanes that were riveted to the cone that goes on the back (front actually) of the alternator. Why did you remove them?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Ah yes, like this…
He was giving me the look when I wasn’t going to disassemble and powder coat.
Senior Member
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Ouch! That hurt Dpmulvan. I guess I’ll put a mouse trap in there. There is plenty of room.
There is a Cat under the car. I’m feeling more confident there will not be a problem.Last edited by porschedude996; 02-28-2024 at 10:47 AM.. |
