Question Threaded Insert
Got our chain cases back from tumbling. Discovered that one of the studs was missing and the hole is not threaded. Is this a DIY job? Given this is magnesium, is it better to heli-coil, case saver, or time sert?
Old 01-30-2024, 11:23 AM
I think you'd be fine with a simply helicoil. Not much torque on these studs.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 01-30-2024, 11:30 AM
It's a 914 ...
stownsen914's Avatar
Strange it's not threaded. Sounds like someone goofed at some point. I'd agree a helicoil should be fine there, if you've got enough meat to work with. If the hold is too big, an oversized timesert or similar should take care of it.
Old 01-30-2024, 02:46 PM
Timesert. I don't care for helicoils in most apps, other than steel/cast iron. Even then, I prefer a solid insert.
206 637 4071
Old 01-30-2024, 03:34 PM
