PCA Member since 1988
Good point too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-20-2024, 03:59 PM
Originally Posted by gled49 View Post
On pull type clutches, you see wear on the thrust surface of the rear main bearing. If trying to reuse mains check axial crankshaft clearance and compare to specs. I check during disassembly to see where I’m at. Rare, but I’ve found crank thrust flange wear from clutch riding.
Yea I noticed that side of the thrust bearing is warn to the copper layer, so you are absolutely right about that, I think I need to replace at least the thrust bearing. All others are almost brand new with their date stamp showing 11/84 .. the engine is is '86 though.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 02-20-2024, 11:53 PM
Check the actual clearance of the thrust bearing. It may be showing copper, but the coating on the thrust face is pretty thin, so it may be well within spec.
Old 02-21-2024, 12:07 AM
