Engine mounted oil cooler question
I see Sierra Madre is selling new engine mounted oil coolers ( aftermarket).
Does anyone have knowledge or experience with them.
TOT
Old 02-20-2024, 06:25 AM
I saw new aftermarket engine coolers at RennSport. They come with interchangeable inlet fittings for different applications. They moved away from the original drawn cup construction to tube and fin design. I suspect they are more robust and they looked pretty nice. Couldn’t find pictures, maybe someone else who saw them will comment.
Old 02-20-2024, 08:20 AM
PCA Member since 1988
The company making them started a thread in this forum about a month ago.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-20-2024, 03:58 PM
CSF Engine Mount Oil Cooler
Thread Announcement - NEW CSF Porsche 911/930 Turbo Engine Oil Cooler
CSF Website
Pelican listing - Porsche CSF OEM+ Performance Engine Oil Cooler, 67-89 911/930
Personally, I would rather have the CSF one than an unknow manufacture from Sierra Madre.
Edit
The Sierra Madre oil coolers that I saw have welded connections for the thread/pipe nipple so it does not appear to be the CSF cooler.
Old 02-20-2024, 08:44 PM
911 tweaks's Avatar
My recent experience with engine mounted oil cooler's is to buy the csf cooler.
I spent 1.5 months scrounging up used oil coolers on eBay, pelican etc only to have all 6 of them fail when being cleaned & tested.
Save yourself all the time & hassle and spend the $$ to get a new cooler…
Unless you like to roll the dice on a rebuild or whatever your reason is…
I live for 911 tweaks...
Old 02-23-2024, 01:05 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Although I have no experience with the latest versions of aftermarket coolers, my experience is that they can't handle the vibrations associated with 911 air-cooled engines.
When we need a new one, we buy the factory original Behr cooler. They are still available and with all things considered, the cost is still reasonable.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-23-2024, 02:38 PM
911 tweaks's Avatar
Old 03-04-2024, 02:33 AM
911 tweaks's Avatar
Depending on cost may your reason on which to buy…
I decided to give CSF a try because it has a 10 year warranty and their video sites, improvement in functionality versus the Porsche OEM bear cooler… Time will tell…
Old 03-04-2024, 02:36 AM
