The hotter an air cooled motor gets the more the aluminum cylinders expand. I guess it boils down to expansion rates between piston, rings and cylinders. I’m not arguing with you, I’ve got a set of these holding up a recent build and it’s sort of ridiculous that we can’t nail down numbers to go by. I guess maybe it’s worth the extra money to just stick with Mahle next time.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
It's a 914 ...
I also found it surprising that there wasn't more consensus on this.
As for heat, expansion, etc., the aftermarket piston manufacturers like JE and CP give different ring gap numbers for street/strip, circle track, boosted race use, etc. My application is race, so wound up using numbers closer to the "circle track" recommendations. I also kept in mind a saying that a knowledgeable fellow shared here on the forum once: Big ring gap = big catch can Small ring gap = big trash can I erred a little on the large side probably. |
PCA Member since 1988
It will run just fine. What little difference it makes, you won't be able to feel.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
It's a 914 ...
Assembly is about the start. I'm hoping to be able to be able to answer that question in the coming months.
I ended up going with .018 top and .020 2nd your cp’s might be different, rather have a little blow by than seize it up.
