Ring gap & head stud confirmation for 2.7
Am in the process of reassembling the top end of a 2.7 and need a sanity check on ring gaps and head studs from the experts.
Mahle cylinders replated and new JE 10.5 pistons. Am thinking 0.18" gaps? Engine has Raceware studs. Any info I got with these has long gone, but IIRC 24 ft/lbs rings a bell? Confirmation or otherwise greatly appreciated... Cheers, Mark
914/6 GT (Repro) Tarmac Rally car 928 S4 - 1989 911SC - 1980 944 TURBO - 1986 944 S2 - 1990 |
PCA Member since 1988
We had a long discussion about head stud torques last week. Because you have a magnesium case, I think most of us agree that you should stick to the Porsche specs for the stud torques--24 Ft-lbs. Does the case have stud inserts?
Rings. Again, stick to Porsche specs. For the 3.0 SC and Turbo engines, the spec book calls for 0.15mm-0.30mm, or .006"-.012" for the 1 and 2 compression rings and the oil scraper rings. Yours should be similar.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
It's a 914 ...
You can ask JE what ring gaps should be for the piston/ring combination they sent you. Make sure they know it's nikasil cylinders in an aircooled, normally aspirated application.
Thanks for the replies. There is a sheet with formulae on it which is where my .018" came from. I just wanted to confirm that with others with recent experience.
I forgot to mention that this is built on a 901/14 case - i.e. sand cast aluminum. Does that make much of a difference for stud torque? Are they all the same regardless of the stud manufacturer?
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
0.1mm = .004", right?
It seems pretty tight to me too, but I took that out of the 1978-1981 SC and Turbo spec book, p.41. SC's have aluminum cylinders, which expand more than iron cylinders, so the ring gaps can be tighter. The 2.7 he wants to build should use aluminum cylinders too. That table is a "guideline only" and the context indicates it is for American iron block engines--completely different animal. Aluminum has about twice the thermal expansion of iron.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-20-2024 at 11:08 AM.. |
bumble: My opinion: Porsche specifies 24 ft-bs torque on the studs because that's more than enough to hold the heads on the cylinders. Keep in mind that is the same spec for the 3.3 turbo engines, which produce more cylinder pressure than the 3.0 or 3.2 or your 2.7. You could go higher, but there is no need to do so, It just puts more stress on the parts, including your very rare early aluminum case. Unless you are building a real race engine, stay at 24.
As stownsen914 recommended, check with the JE and/or the supplier for their recommended end gaps.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-20-2024 at 11:05 AM.. |
Thank you all so much for the replies.
The ring end gap table was what I used to get .018" for all rings given the engine use - weekend sports car/DE/canyon carver sort of thing. Not an all-out race engine but fairly hot all the same. FYI: Aly case, 97mm spigots & a LOT of mods to reduce pumping losses Std crank cross drilled, knife edged etc etc... Turbo oil pump Turbo oil squirters Std rods balanced and re-bushed using Raceware rod bolts This was prepared for me by John Williamson (Otto - RIP) back in the day and did 10K miles before I 'retired' it 10.5 JEs Resized and replated 90mm Mahle cylinders mooned to match the case. I was going to rebore to 92mm but was advised against it by someone (Henry probably). Webcam 171e/149i cams Refurbed rockers and idlers supplied by Henry 38/38mm ports with matched inlet manifolds 46mm Webers with 38mm venturis Fabspeed SS headers Magnalow 2 in 2 out Twin plugged etc So, pretty much old school as could have been seen in the '70s. 24 ft/lbs it is for the studs then - thanks Peter. I couldn't remember whether there was anything particular about Raceware studs that might alter that - but it appears not. Cheers
It's a 914 ...
Sounds like a nice motor
It's a 914 ...
When I talked to CP about ring gaps for my 911 engine, they recommended larger than what was listed in the table due to being aircooled.
Why larger?
Dp, thanks for that reference. If Charlie Navarro says ignore JE and use the Porsche specs, that's about as authoritative as you can get.
Well, The Keeper of The List showed up and hijacked me to do 'more important things'. Normally this is a Bad Thing but in this case has prevented me from being a tad hasty. If the experts recommend Porsche's figures then that's what I'll follow. I'll measure the out of box gaps tonight and see how close they are to the recommended -15 - .30mm figures and go from there.
Thanks again for the input...
Measured the out of the box ring gaps. Very consistently they are:
Top - .010" 2nd - .020" Oil - ..020" Given what Porsche recommends, I think I''ll stick with these numbers. Saves a bit of filing...
Half the people say go with Porsche numbers and the other half say go with JP. Some say aluminum cylinders expand too much to go with JP numbers, others say mahle and JP pistons are different alloy and JP pistons will expand more than mahle and therefore you need bigger gaps.
It's a 914 ...
I assume it's due to aircooled running hotter than the more typical water cooled applications covered in CP's published specs. I confirmed with a Porsche engine builder. This was an area I had no expertise, so I deferred to theirs.
