Banned
Engine rebuild
I’m at the point where I need to rebuild my 3.0 original engine. I’m considering the options. Since I’m looking at sinking so much $$ into a rebuild I’m considering all options. Who has experience buying 3.2 engines?
Is there a resource for finding one or am I just going to be hunting and cruising eBay? Thanks in advance for advice on whether to swap or not, and if so, how, and what becomes of the original engine? Should I keep it or sell it to offset cost of a 3.2. I’m inclined to keep it original personally. |
Senior Member
If the car is all original don’t sell the motor, keep it. Buying motors is always a crapshoot regardless of what the seller tells you. If you got money to burn buy a 3.2 and shelf your 3.0. Or just build a nice 3.0 nothing wrong with a well built 3.0.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
PCA Member since 1988
Too little info. You didn't even say what year car or how many miles. Keep the CIS or change to carbs or EFI? Budget? Etc.
If I were buying a complete engine, I would only buy one from a recently wrecked car that I could be sure of the miles and condition before the car was wrecked. Otherwise, as DP says, it's a crapshoot.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
The 9 Store
I have a rebuilt 3.2. Elgin performance cams, pauter rods, euro compression, clevite rod bearings, coated main bearings, reconditioned rockers, reconditioned injectors, etc. If I’m selling with Ecu and harness, it will be $35k. If interested, PM me. Mark
Right now it’s a long block but I can dress the engine and have it ready in 2-3 weeks.
All used parts sold as is. |
Banned
Alright thanks @Dpmulvan |
I'm rebuilding a 3.0 SC engine into a 3.2 short stroke w/ EFI.
there is a nice 89 3.2 motor for sale here on Pelican for a good price. You might want to consider a 3.6 also
3.2ss
The 3.0 to 3.2SS is one of my favorite builds
regards, al PS: Give me a shout......
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Al,
I sure hope my 3.2SS turns out like that engine! Greg |
E-85 sippin drunk
So, you have 2 options... rebuild the 3.0L ( and in the process, make it killer!!), or spend the $$$ and buy a used 3.2 or 3.6L. All the options above will work. It all depends on the depth of your pockets.
If you buy a used engine, you could very easily be buying someone else's problems! If you rebuild yours, at least you know you have got a solid engine, and will enjoy it for years to come. It is all based on your $$$. A used 3.6L will cost you as much as the full rebuild on your 3.0L especiallyif you go with go fast parts ( 3.2L SS, carbs or EFI, higher compression, headers, etc etc)
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
The 9 Store
I just got in a used 3.2 that was traded for a newly rebuilt 3.6. Good running condition. I’m not sure of the history since it’s not original to the car. Reach out to me if you are interested. Mark@MarkEpstein.net
Senior Member
50 seconds!! One of your longer YouTube videos. Love it.
