PCA Member since 1988
SC distributor spring orientation
I confess that I was a taking apart my dizzy to clean and lube it (Guenther's directions), and I pulled on the rotor part enough that the springs came off the posts in the lower part of the distributor cup. So I lost the orientation of which spring goes to which post. It might not even matter, but I'm asking to be sure.
Thanks in advance.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-04-2024, 09:45 PM
AndrewCologne's Avatar
As your engine is from 1980, maybe this is useful ... as also one image shows the inner mechanism and how the springs are installed:
https://nineelevenheaven.wordpress.com/maintenance-of-the-distributor/
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 04-04-2024, 11:07 PM
Andrew, that's perfect. Thanks.
Old 04-05-2024, 11:14 AM
To update this thread for future searches: I also found another picture in an old thread here that showed the springs on opposite sides. Hmmm. Maybe it does not matter?
I then carefully observed the action of the springs and flyweights on the lobes of the rotor. I noted that the springs do not connect to the flyweights (as they do in some American engines). Instead the springs are connected to posts on the rotor lobes, and the flyweights act on the rotor lobes against the spring pressure on them. Therefore the location of the springs on one pair of posts or the other does not matter. They act in parallel either way.
Old 04-05-2024, 09:39 PM
So the clip under the felt was not installed?
Old 04-07-2024, 03:31 PM
What clip under the felt? There is a screw under the felt in the center of the shaft. If you mean the circlip around the shaft, yes both were there and I removed them to pull up on the shaft, which is when I popped the advance springs off the posts.
Old 04-07-2024, 10:36 PM
