Porsche Crest 1976 2.7L Engine build suggestions
I recently purchased a 1976 911S 2.7L motor. I am restoring a 1973 911 Targa that I will be putting this motor into. I need some suggestions on engine design options. This is my first Porsche Engine reubild.
Here is what I have
The long block is all together. camshafts look to be in good shape
Engine turns over and seems to have good compression
Here is what I have
CIS Camshaft
Carrera tensioners
Turbo valve covers
1970's Heat exchanger exhaust system
I am looking to leave the long block as is, replace some seals but don't crack the case, for now.
Looking to do a more modern EFI system - suggestions on which ?
Replace stock distributor with MSD Box and blaster - suggestions ?
Exhaust, keep old school heat exchanger or go to stainless steel headers
Anything else I should be thinking about as I clean up and rebuild this motor ?
Jared
73 Porsche 911 Targa
57 Chevy 3100
Old 04-08-2024, 07:50 PM
PCA Member since 1988
Did it have case-saver inserts installed for the head studs? Is it original? What else do you know about the history of the motor and what parts were put into it?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-08-2024, 10:09 PM
case-saver inserts look like they were installed. Not sure of any other upgrades besides what I listed above.
Jared
57 Chevy 3100
Old 04-09-2024, 03:38 AM
2 of my valves look a little crusty inside. Any suggestions on what to do and why this would happen ?
Jared
57 Chevy 3100
Old 04-10-2024, 04:55 PM
That's rust and it looks like water sat in the ports for awhile. I would then suspect that the intake valves that were open allowed water into the cylinders. The intake manifold stud in that picture is also pretty rusty. At a minimum, I would put a camera into the cylinders through the spark plug holes and inspect them for signs of water or corrosion.
Did you get any of the CIS system with it, or just the long block? Lots of threads here about EFI for air-cooled engines, so spend some time reviewing those.
And what's your budget?
Old 04-10-2024, 11:01 PM
I only have the long block. I am looking to add an EFI system, yet to be determined. Not totally sure on budget. I want to build the motor right but also don't want to break the bank.
I put a camera in the cylinders. For the most part they look good. A few cylinders have a good amount of build up.
let me know your thoughts ? Do I need to open up these cylinders ?
Jared
57 Chevy 3100
Old 04-12-2024, 04:51 PM
SalParadise's Avatar
With that amount of rust it does show that water was sitting and/or weeping into the cylinders. Where did you get this engine? I am not too sure if I would trust it without pulling the top end off. Just because it "turns over" doesn't mean the cylinders are not pitted, corroded or otherwise.
Was this some online purchase or local?
Old 04-12-2024, 07:44 PM
That's not a very clear picture, but I agree with Sal. I would take off the heads and inspect the cylinders and pistons and rings more closely.
Old 04-12-2024, 11:07 PM
