911 SC flywheel question please
Hi everyone
I’m building a 76 911 with an later SC case 80-83, however the trans is a 78-81 915
Does it matter what flywheel I use. Where there different flywheels between 78-81
Thanks in advance
Old 04-18-2025, 07:26 PM
SC engine will have 9 bolt crank/flywheel, all SC’s were the same.
Old 04-18-2025, 07:45 PM
Originally Posted by jess p View Post
Hi everyone
Thanks in advance
I think the only difference between early SC and later SC is that the early SC crankshaft didnt have the 3 threaded holes for the pilot bearing. The flywheel for early SC used a press in pilot bearing.
The later SC had a 3 bolt pilot bearing and the crank was drilled to accept the bolts. The flywheels are only different in terms of the mounting for the pilot bearing.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 04-19-2025, 01:52 AM
Flywheel
Thanks for the info
Old 04-24-2025, 01:14 PM
