911 SC flywheel question please
Hi everyone
I’m building a 76 911 with an later SC case 80-83, however the trans is a 78-81 915 Does it matter what flywheel I use. Where there different flywheels between 78-81 Thanks in advance |
SC engine will have 9 bolt crank/flywheel, all SC’s were the same.
The later SC had a 3 bolt pilot bearing and the crank was drilled to accept the bolts. The flywheels are only different in terms of the mounting for the pilot bearing.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Flywheel
Thanks for the info
