3.6 track engine
I am building a 3.6 track motor with CR being 12.45 to 1.0. Was thinking I wanted no more than 12 to 1. I can remove 1.6cc from the dome and get it down to 12.0. I don't know a magic number for compression on these motors. The 3.6 is I think more susceptible to blow by due to the additional span of its cylinder heads. does a half point matter. Any good info greatly appreciated. Bob
Try not, Do or Do not
I believe there is very little performance difference between those compression numbers.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
This is where you will get schooled on static compression and dynamic compression from the board.
The last 993 3.6 liter I built was 12.5 : 1 CR (static,JE pistons) , GE100 cams , twin plug ,Carrillo rods and on the dyno 319 RWHP. Of course this was on race fuel. If this is for a track car why do you want to lower compression? Blow by? I didn't have any issues, logged around 30 track hours on the engine then sold it.
'77 1973 911RS Backdate, 2.7 liter w/webers '70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress '75 911 RSR street car in progress '77 930 Replica '75 993 GT2 EVO race car , 3.6 TT '79 928 5 speed money pit in progress Last edited by pocv0; 07-16-2024 at 07:47 AM.. |
