1975 911 3.4 outlaw/hotrod? lsd
1988 535i
1987 535is
1973 bronco ranger
Old 07-17-2024, 10:18 AM
I'm guessing the wrist pin on one was floating due to a missing circlip? Just one ? So maybe you just need one piston and cylinder? Or are the other cylinders scored as well ? Just curious.
'77 1973 911RS Backdate, 2.7 liter w/webers
'70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress
'75 911 RSR street car in progress
'77 930 Replica '75 993 GT2 EVO race car , 3.6 TT
'79 928 5 speed money pit in progress
Old 07-17-2024, 10:33 AM
or maybe a broken ring...that must be it. The galling is 90 degrees from the wrist pin location.
Old 07-17-2024, 10:36 AM
proporsche's Avatar
yup it does not look good....it got hot..see those marks on the piston...wrist pin was very easy to take out,right? Yup those chain gears look bad too but that was not your noise..i have seen worse...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-18-2024, 01:46 AM
proporsche's Avatar
those spots on the inside of the cylinder and one pistons really looks like water spots(corrosion) and being polished out...right at your index finger..
Ivan
Old 07-18-2024, 06:07 AM
1988 535i
1987 535is
1973 bronco ranger
Old 07-18-2024, 07:21 AM
Doubt your supposed to add goo to the piston base gaskets.
Other pic is the idler arm bushings
1988 535i
1987 535is
1973 bronco ranger
Old 07-18-2024, 07:22 AM
proporsche's Avatar
yup some mechanics use this stuff on the copper ,i do not...but it almost looks like the engine was starving for oil
Old 07-18-2024, 08:17 AM
It's a 914 ...
stownsen914's Avatar
Some recommend non-hardening sealant like curil T for cyl base gaskets. I’m probably going to give that a try for my motor that’s about to go together.
Question about what to look for on cam chain gears for wear. I’d understood that wear in the U is a key thing to look for, along with thinning of the gear teeth. And of course any chips or other damage. What else?
Old 07-18-2024, 03:25 PM
It's common and sometimes actually recommended to use a very thin layer of Curil T.
I have pulled apart an engine where they used the grey 1104.. it's not recommended but that engine performed fine and it didn't cause issues.
Using Curil T, allows some time to bolt on the heads and torque down. But if using the grey stuff (or anything that is NOT non-hardening) I would imagine you'd potentially have issues if it cured before you got your heads on and torqued.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 07-18-2024, 04:35 PM
Man, it looks pretty whipped all around. You have my sympathy. I’d want to find a smoking gun to feel good about avoiding it the next time.
Ken
1986 930 2016 R1200RS
Old 07-18-2024, 04:51 PM
#5 rod bearing
1988 535i
1987 535is
1973 bronco ranger
Old 07-19-2024, 12:01 PM
proporsche's Avatar
#5 rod bearing
pretty bad...where o rings on the oil pump in correct place---and are they green?
The other rod bearings same or ok?Is there any discoloration on the bottom of the rod-like it got hot?
Ivan
Old 07-19-2024, 12:06 PM
Crank looks good. Past fingernail test.
One of the rod bolts did not feel torqued compared to the other.
I havnt split the case test. Just looking at #5.
1988 535i
1987 535is
1973 bronco ranger
Old 07-19-2024, 12:11 PM
proporsche's Avatar
at least a little good news..
Old 07-19-2024, 12:36 PM
Took my heads pistons and cylinders to Walt at Competition Engineering. Walt is amazing. Super nice guy. Long drive. I didn’t look to well because he found a broken exhaust valve guide. Thank god it was on the exhaust side. And I’m glad I started the teardown which exposed this. So the heads will get redone. He said my pistons and cylinders looked great. So better in person. He said noise had to be the tensioners and to just replace them. This is consistent with any of the expert porsche mechanics. I probably will not split the case seeing this motor still looks new and has very low miles/hours. Walt didn’t think it was necessary.
1988 535i
1987 535is
1973 bronco ranger
Old 07-20-2024, 02:22 PM
PCA Member since 1988
You can trust Walt. I would not split the case either, unless it is leaking and you want to reseal it. Otherwise you risk getting crap into the oil passages, which will then embed in the bearing shells.
That #5 rod bearing looks good to me. Yes, there is some embedding of a soft metal (almost certainly aluminum bits), but if it passes the plastigage test, I would put it back in as-is. It has already bedded to the crank journal, so don't mess with it! Likewise for the other rod bearings; put them back into the same place and do NOT replace them.
Some vertical marking in the cylinders and on the piston skirts is normal. I would not mess with those either. At most, break the glaze, but put it back together with the same pistons/rings in the same cylinders. Since you say this is a race motor, you will be pulling it apart at regular intervals anyway, so don't worry about minor wear. And expect more wear, because you are flogging it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-20-2024, 02:44 PM
You are consistent with all the other pros. I only removed #5 rod. I might remove #2 rod to examine
Lots of good news today. Even finding a broken valve guide eases my mind of needing to tear into the top end.
1988 535i
1987 535is
1973 bronco ranger
Old 07-20-2024, 04:29 PM
Those bearings look fine. Make sure there's some "crush" left when you reinstall them, and check the clearances with plastigage if you don't have micrometers and a dial bore gauge.
Old 07-20-2024, 04:38 PM
It's a 914 ...
Good news!
What did Walt say about your cam gears? I ask for a selfish reason, as I'm about to assemble my own motor and wondered about some of the comments you got earlier in the thread.
Old 07-20-2024, 05:52 PM
