3.2 race motor warm noise help
I had this over in the tech area where I am getting a lot of help.
timing chain?
piston slapping?
cylinder not firing?
Wrist pin?
sound out of the exhaust is great. but it backfired that last time I tried to start it. No oil leaks. no smoke at all. change oil with no metal shavings at all.
seems like timing is off. but would that make this knocking noise? goes away with revs.
CP pistons 95mm 9.5:1
911 chips custom 91 octane
Cold start. Sounds normal. But idle is a bit higher when cooler.
https://youtube.com/shorts/xoCcPnAEDok?si=KRrkkt-5kqOdrV36
Warm. Knocking sound shows up. Idle lower when warm.
https://youtube.com/shorts/m-xKjY6AADo?si=Sk4BD-UZcyNchIK2
1975 911 3.4 outlaw/hotrod? lsd
1988 535i
1987 535is
1973 bronco ranger
Old 07-06-2024, 06:58 AM
I hear a dull clatter on the second video..What happens to the noise when you blip it and on decell. Bob
Old 07-07-2024, 09:23 AM
Smooths out. Or a bit less noisy Until idle drops down to normal warm rpm
1988 535i
1987 535is
1973 bronco ranger
Old 07-07-2024, 10:14 AM
JoeMag's Avatar
did you try to take an automotive stethoscope to it to see if you can hear where it’s coming from? About a leak down check?
Old 07-07-2024, 11:24 AM
Stethoscope found most noise front right timing cover. Inspected and didn’t see anything super unusual that would cause this type of noise. Valves adjusted. But found side to side play on arms. Race car that’s been sitting for over 2 years with no real driving on it. Fully rebuilt on 2008. CP Pistons added in 2013. Don’t see any metal at all on two oil drains. No smoke. Motor looks super fresh. But something inside is not right.
I’m going to tear into it before anything really bad starts to happen. Kinda excited about it but lots to learn.
1988 535i
1987 535is
1973 bronco ranger
Old 07-07-2024, 12:57 PM
917_Langheck's Avatar
Do you somehow expect a different series of questions and answers in the forum vs the one where you originally posted?
If you are running race components in your motor as you indicated previously, then maybe you should get the motor up to race temp to see if the issue is still present. Otherwise, tear it down and mic the parts for adherence to specifications.
Old 07-07-2024, 06:55 PM
Yes. It was recommended to me that I post here because some of y’all are not always looking at the tech section.
Actually from the records it looks stock 3.2. CP piston 95mm 9.5:1. And Carrera cams
I’ve had it up to temp and seems to just get louder. I really don’t feel safe running it until I get into the motor. Motor is super dry and clean. So maybe I’ll get a small break on the cleaning and hopefully not too worn newer parts.
1988 535i
1987 535is
1973 bronco ranger
Old 07-07-2024, 07:12 PM
7.0:1 > 11.3:1 > 7.0:1
Another potential thought. Maybe the engine ingested a small bit of hardware in cyl 4 or 5 (since you say the noise seems in or close to the rt chain box. With the engine at BDC 4, then 5, use a bore scope to see the piston crown
Old 07-07-2024, 07:29 PM
I got seasick watching those vids. It helps to hold the camera steady and slowly pan across to the different areas you are trying to capture.
That being said, maybe pull your timing covers off and check that your tensioners have not collapsed.
Share a photo with the covers off, or a slightly more stable video
Always learning.
www.aircooledporsches.com.au
Old 07-08-2024, 12:31 AM
Slim chance but an easy check, is the noise still there with the fan belt off?
Old 07-08-2024, 04:57 PM
We aren't all academy nominees like you mate, haha
Old 07-08-2024, 04:58 PM
proporsche's Avatar
Mike the video on technical -what was the reason for it..Not just to look on the oil right?There is a scraping sound in it...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-09-2024, 03:06 AM
I think it has to be timing chain related. It could be the chain guides are misaligned , the sprocket bushing is failing, or missing spacer , or an incorrect spacer between the idler sprocket and housing . Last , tensioner failure. JMO
'77 1973 911RS Backdate, 2.7 liter w/webers
'70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress
'75 911 RSR street car in progress
'77 930 Replica '75 993 GT2 EVO race car , 3.6 TT
'79 928 5 speed money pit in progress
Old 07-09-2024, 06:22 AM
1988 535i
1987 535is
1973 bronco ranger
Old 07-16-2024, 06:20 AM
1988 535i
1987 535is
1973 bronco ranger
Old 07-16-2024, 06:29 AM
It's a 914 ...
stownsen914's Avatar
Never mind, I mixed this thread up with another one.
Old 07-16-2024, 03:25 PM
Sounds like a tensioner failed. Which ones does it have?
Old 07-16-2024, 04:28 PM
Tensioners are fine.
1988 535i
1987 535is
1973 bronco ranger
Old 07-16-2024, 08:22 PM
wow, looks like the pistons are toast, timing chain gears, chains and sprockets as well. Cylinders scored?
Old 07-17-2024, 07:17 AM
DIY wrencher
That doesn't look very good mate, sorry about your bad luck!
Any idea yet what happened yet? Was this an oiling issue or how did the piston skirts get scuffed up this way? Debris in the timing chain area?
88 911 Carrera 3.2 G50 - driver
77 911S - rust bucket backdate project
IG: @lukas.matzinger
Old 07-17-2024, 08:31 AM
