DIY wrencher
Experience with Mahle high compression 3.2 -> 3.4L kits?
Hi guys,
I am currently planning out the rebuild of my 220k kms 3.2 engine, with worn valve guides and a broken head stud. Unfortunately it's the low compression 217 HP cat version, even though it's a Euro car. I'm still running the numbers on rebuilding mostly stock but with Euro 10.3:1 pistons, vs. upgrading to 98mm "while I'm in there". If I do that Mahle offers the 98mm 10.1:1 Max & Moritz kit (Mahle PS98-010) that maxes out what you can do with single plug and Motronic, but "while I'm in there" they also have a 11.0:1 kit that allows you to run bigger cams and has a shape optimized for twin plug (PS98-017). Does anybody have experience with these kits, and is it worth the extra cost of going 3.4L M&M single plug (approx. $1500 extra vs. just a set of pistons) or 3.4L high compression twin plug (another $1500 or so on top with head work, Steve Wong DME mod + splitter + used 964 dizzy)? Thanks for your input! Cheers, Lukas
88 911 Carrera 3.2 G50 - driver 77 911S - rust bucket backdate project IG: @lukas.matzinger |
The 9 Store
You can also rebore your old cylinders and then pick any piston you want.
It’s best to look at the engine as a system and build from the bottom up.
All used parts sold as is. |
DIY wrencher
That's true and it's something I have also considered, but if I factor in the value of the core cylinders, shipping + return, etc the bore and replate only saves a few hundred $. Given that quite a few people have had with problems with cylinder roughness vs. ring seating after replating and the different expansion rates of the alloys used in aftermarket pistons vs. Mahle cylinders leading to some piston (slap) noise, I am wondering if a new Mahle piston in a (new/used) Mahle cylinder might be worth the extra cost for piece of mind and longevity?
Rosco_NZ
I think the engine start noises with JE Pistons are a thing of the past with updated 4032 & latest JE design
I installed a set of 3.4 Mahles in my nephews 911. They have been flawless from the get go. I have 98 mm JEs in mine and oil consumption is more than the Malhe but still well within acceptable limits. The JE pistons use a much thinner oil control rings and I suspect that is the reason for higher consumption. In summary, both are good.
1986 Targa Guards Red 2021 MT09 SP |
Just as long as you prep all surfaces of the mahle motorsport rings , this is your best bet .
The rings tend to have burs on them . Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Thinking about this as well. What is the power difference 3.2 vs 3.4? Roughly?
1975 911 3.4 outlaw/hotrod? lsd 1988 535i 1987 535is 1973 bronco ranger |
DIY wrencher
Did you have to gap the rings as well, or were they within spec? Quote:
Did you go with the standard Motronic 10.1 compression kit, or the higher 11.0 one? Quote:
Interesting read here! Mahle vs JE
88 911 Carrera 3.2 G50 - driver 77 911S - rust bucket backdate project IG: @lukas.matzinger Last edited by LukasM; 08-25-2024 at 07:40 AM.. |
quote "Did you have to gap the rings as well, or were they within spec?"
The rings were gaped properly , the mfg burrs were a problem. Take a cotton ball and dress around each ring , it sticks to burrs . Ian
D |
lower rings , top ring not so much , just check and knock off the sharp edges from the gapping process Ian
I’m trying to figure this out while I have the entire motor torn apart and at the machine shop. Not sure if there is a better all around option than 98mm P&C 9.81 compression ratio and 964 cam SW chip. Is an added knock safety sensor still needed? CP or JE pistons?
A bit old now but lots of good info: https://forums.pelicanparts.com/porsche-911-technical-forum/851793-3-2-3-4-must-you-go-twin-plug-3.html
Stubble- I just did the upsizing from 3.0L to 3.2L and kept my CIS- a bit different from your concept. But, based upon that, I recommend doing the following:
1. Call William Knight to learn his experiences with such projects. He knows what works and what doesn't work. 2. Suggest spending the $4K and getting the Mahle 98mm piston & cylinder KIT made for your project, if William agrees. 3. William will recommend best cam for your application. 4. Prepare to be impressed. That's the best recommendation I can give you. |
Ok. Great. Thank you.
I have called EBS. With core exchange 98 mm cylinders $1470 JE pistons $1450 Supertec has a 97mm for around $3700 964 cam. Either webcam or having mine grind down. I can get a deal with a barely used webcam for $600 But I’ll check with William. Thanks
DIY wrencher
If you e got a link for that let see it. I don’t see anything under $4600
Stubble- I just sent you a PM. That should get you started. I seem to recall William mentioning in another thread that this upsizing from 3.2L to 3.4L has a couple challenges in order to reach its full potential. But William knows the tricks and will steer you towards the best path for your application. Don't be surprised if he recommends a different cam than you are considering; Suggest waiting to discuss with him prior to buying anything. Please report back when you determine your direction. Thanks
