86 911's Avatar
Send a message via AIM to 86 911
Case Hardware Question
After many months, I am going to put my 3.0 SC engine back together. Tonight, I opened my little baggie of case hardware and cleaned everything up.
I will be replacing the washers and nyloc nuts. I noticed that the original nuts are yellow zinc. I purchased clear zinc coated steel nyloc nuts (see baggie at the top). I assume these are fine?
Also, can I re-use the beveled case thru bolt washers? I am referring to the three washers in the bottom of the photo (of course there are a lot more on the thru-bolts not shown here).
Matt
'76 Porsche 911 with '78 3.0 SC engine
'71 VW Bus
'14 VW Passat (toddler hauler & wife approved ride)
'03 Subaru Baja original yellow & silver
Old 10-13-2024, 07:26 PM
Yes you can reuse the beveled washers, nuts are fine if you want them yellow dip them in a dilute acid 5% rest water for 30 seconds followed by a 30 second dip in sodium dichromate.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 10-14-2024, 06:38 AM
86 911's Avatar
Thanks for the info!
Old 10-14-2024, 11:33 PM
PCA Member since 1988
Agree with Dpmulvan. Those look pretty good in the picture. If they are not pitted with corrosion, reuse them.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-15-2024, 02:42 PM
My one minor regret in my own engine rebuild was not to ship off all the hardware for refinishing while the major parts were out being machined etc.
Does it add HP? Nope. But it just looks so much nicer. And that's part of enjoying a hobby too.
Future engine builders: add it to the punch list!
Ken
1986 930 2016 R1200RS
Old 10-16-2024, 12:47 PM
Hah! After you put the fan shroud and induction on, you won't see them.
Old 10-16-2024, 03:39 PM
Jeff Alton's Avatar
We clean, tumble and replate those parts....
Cheers
www.turn3autosport.com
Old 11-06-2024, 08:30 PM
Don
Go titanium
Old 11-07-2024, 01:21 PM
