Hastech Engineering Tensioner Woes - Help
Do custom idler arms exist that are larger to avoid this issue? see below.
Old 11-10-2024, 12:54 PM
targa72e's Avatar
Yes they are available. The one on the left came out of a engine I recently purchased. The one on the right is stock the left is larger. Unfortunately I do not know who makes these.
john
Old 11-10-2024, 02:08 PM
Thanks John! Looks like mine is 19 teeth, so 20+ teeth would probably be good. I'll keep hunting.
Old 11-10-2024, 02:19 PM
Maybe a couple of new chains?
206 637 4071
Old 11-10-2024, 03:23 PM
I measured this chain and it wasn't any longer than the new chain.
Old 11-10-2024, 03:45 PM
That surprises me.
Look how close the chain is to the upper guide in your photo... pretty sure a new chain wouldn't get that close as per below?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 11-10-2024, 10:42 PM
Send a message via AIM to 69 911s
Apparently, things got narrower after machining.
when you see hoof prints, dont automatically assume zebras
Old 11-11-2024, 03:55 AM
A smaller sprocket isn’t going to help, you’ll have to push it even farther up to tighten.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 11-11-2024, 04:17 AM
Never mind I just got up
Old 11-11-2024, 04:21 AM
It's a 914 ...
stownsen914's Avatar
Is this an engine you’re assembling? How’s your deck height?
Old 11-11-2024, 08:30 AM
47silver's Avatar
take a link out of the chain?
1975 911S Targa
Silver Anniversary Edition
Old 11-12-2024, 05:40 AM
JoeMag's Avatar
What was "machined"?
Old 11-13-2024, 12:19 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The chains don't actually stretch. The rollers can get play in them creating the situation you see. We built a tool to test this wear.
The larger sprocket comes from an early sixties Mercedes 220, 250, 280? Too old to remember which.
If you had the case halves machined, chain length is only part of your problem.
If you want to shorten the chains, you need a half link. A whole link makes the chain too short.
We haven't done this in 30 years, a little half-assed so forgive me if the answers are a little fuzzy.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-13-2024, 12:48 PM
targa72e's Avatar
I looked at some old notes. You might try the following companies as I believe they have larger and smaller idler wheels if needed. Once is burnham performance and the other is Rothsport.
john
Old 11-13-2024, 01:01 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
I would avoid half links at any cost. The inherent weakness of the bent side plates is something you do not want to experience.
1986 Targa Guards Red
2021 MT09 SP
Old 11-13-2024, 02:33 PM
Constitutional Liberal
Turbo_pro's Avatar
What evidence do you have that a half-link is "inherent weak" and would jeopardize longevity in this application?
Chain loads in the application are relatively light. How do I know, one of my older vintage race engines has single row chains.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 11-13-2024, 03:18 PM
Rothsport didn't have the idler wheel. Mittelmotor did. We'll see if that helps. Anyone know why the shelf came to exist under the right sprocket? Earlier models don't have that aluminum shelf in the timing chain box.
Old 11-14-2024, 11:20 AM
47silver's Avatar
shelf
looks like it would flip oil up to the chain?
1975 911S Targa
Old 11-14-2024, 11:38 AM
Save yourself time and money just remove the chain box and machine a relief in it.
Old 11-22-2024, 06:24 AM
I can double the advise that removing a link is "a mile" and then your chain will be much too short. You may try JB racing in FL as they may have a larger diameter sprocket to fix your problem . Another item to check: if you narrowed your engine that much by cutting the deck surface, and the heads(the only way this happens) you may want to revisit your cam centering up in the chain box opening with as much as this engine seems to have been narrowed. We, in his situation cut the chain box an equal amount to keep that centered so it doesn't leak like a siv when together. This will ensure a good
seal , however will make your sprocket problem even worse.
Kevin
GAS Motorsport
Upland, CA
Old 11-24-2024, 11:17 AM
