I am my 911's PO
Sealant for NPT plugs in cam tower
What are you using to seal NPT plugs installed in the cam towers? I'm building an engine for my track car and I tapped the cam tower openings for NPT plugs to facilitate cleaning the spray bars. So far I've only facilitated leaks.
A search here shows a variety of sealants used for threaded and plain plugs: none, blue/red/orange/green Loctite, Permatex Aviation ("camel snot"), anti-seize (?). Obviously the sealant has to stand up to 200F oil at 2-3 bar. Any recommendations? TIA, Steve
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive |
Loctite 592 for <400F. It hardens up. Loctite 567 for <300F, it doesn't harden up.
I am my 911's PO
Here are some details for anyone else with a similar need: Loctite 592 Datasheet The high lubricating properties of LOCTITE® 592™ prevent galling on pipe threads and fittings. It will provide immediate low pressure sealing and allow the readjustment of fittings shortly after assembly. After 72 hours the joint is sealed to pipe burst pressure. This product is typically used in applications up to 204 °C. T Loctite 567 Datasheet LOCTITE® 567™ is designed for the locking and sealing of metal tapered threads and fittings. The product cures when confined in the absence of air between close fitting metal surfaces and prevents loosening and leakage from shock and vibration. LOCTITE® 567™ provides robust curing performance. The high lubricating properties of this compound prevent galling on stainless steel, aluminum and all other metal pipe threads and fittings. It not only works on active metals (e.g. brass, copper) but also on passive substrates such as stainless steel and plated surfaces. The product offers high temperature performance and oil tolerance. It tolerates minor surface contaminations from various oils, such as cutting, lubrication, anticorrosion and protection fluids
PCA Member since 1988
Teflon plumbing tape works pretty well too, and doesn't seize.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
What auto manufacturer recommends teflon tape on anything? The vast majority of them specifically forbid the use of teflon tape because the little shards can end up plugging things.
Paste yes. Tape no. |
Try not, Do or Do not
At Supertec we hate oil leaks. It's like a religion to us.
Over the years we've developed a habit of using a light smear of 574 Loctite on all fitting threaded and pressed fitting that constitute a potential oil leak. Even those fitting that use an aluminum or copper sealing ring. One exception is the crank plugs. For those we use LT high vibration green. It's a technique taught to us by one of the world renowned Porsche engine builders, Dean Polopolus (Polo Fame). Simple, reliable and easily removed.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I am my 911's PO
Henry,
Just to clarify, LT Green on the crank plugs because you want its strength and high prevailing torque to keep the plugs in place and LT 574 everywhere else because only the sealing (not retention) properties are needed?
Tape is fine for cam tower plugs if you know how to use it, it’s not the space shuttle.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Yes
Best practices when available either by experience or manufacturers specification are advised. In 40 years and over 450 air-cooled engines I have never seen a good application for Teflon tape.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-25-2024 at 02:35 PM.. |
