MFI parts
Anyone have a resource or supplier for new idle speed air bypass screws (Qty 6) for MFI throttle bodies? Checked with a number different sites with no luck.
thanks!
Old 12-10-2024, 05:02 AM
(man/dude)
Jonny042's Avatar
The part you are looking for is part #90111011201 and the spring is #90111011901. Please be sure to confirm this independently with the parts diagrams, but the picture appears to match.
They don't seem to be available from our host (ALWAYS the first place to go if you can!)
Rosepassion.com seems to have stock:
https://www.rosepassion.com/en/adjusting-screw-P277743
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 12-10-2024, 06:53 AM
(man/dude)
Jonny042's Avatar
PS - Not certain if the early 2.2 MFI throttles would use the same as the 2.4 MFI - I'd need to check to be sure. But they do look right.
Old 12-10-2024, 06:58 AM
Many thanks! They do look correct. Even the knurling matches. I’m going to check with them first since the description doesn’t say anything about “MFI idle air bypass screws”. And I’m pretty sure I’ve seen the same graphic used in Carb jet catalog pieces….
nice work, Jonny! I’ve learned a lot from your posts.
Old 12-10-2024, 09:11 AM
