cam towers install
I am dry fitting cam towers with the heads on the case and i notice it has a little rocking up and down motion, approx .25mm.
All cleaned. Nothing appears to hinder and it appears to be flat with a straight edge on the cam tower. It does this on both cam towers. I noticed on rebuild videos people hammering them down so it would seem they wouldnt even notice if there were any play. However, mine does not need to be hammered, they just fall into place. Is this normal? I imagine once i torque the heads down the base gaskets will even and everything will all conform? Last edited by JHP; 12-22-2024 at 02:25 AM.. |
you don't happen to have 2 base gaskets stacked under 1 cylinder?
Always learning. www.aircooledporsches.com.au |
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
I don't know about hammering, all mine needed was a firm push to get the o-rings for the oil return tubes seated.
Ed 1973.5 T |
If you don’t find a smoking gun, carry on. After you torque the heads and cam towers make sure the camshaft turns nicely in its bores by hand. If it binds you definitely have an issue.
- Daniel
it's not leaking....it's just marking it's territory |
May well be hanging up on one of the retun tube O rings - like Ed mentions.
That would explain the hammering down with no issues on other builds. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Repeating what Zuffenwerker said, once torqued down, make sure both the cams rotate freely. It doesn't take much cylinder height difference to cause binding of the cam. For the first test assembly, don't use any sealant, if the cams turn freely, remove and apply. Good luck.
1986 Targa Guards Red 2021 MT09 SP |
