JHP JHP is offline
cam towers install
I am dry fitting cam towers with the heads on the case and i notice it has a little rocking up and down motion, approx .25mm.
All cleaned. Nothing appears to hinder and it appears to be flat with a straight edge on the cam tower. It does this on both cam towers. I noticed on rebuild videos people hammering them down so it would seem they wouldnt even notice if there were any play. However, mine does not need to be hammered, they just fall into place.
Is this normal? I imagine once i torque the heads down the base gaskets will even and everything will all conform?
Old 12-21-2024, 04:49 PM
you don't happen to have 2 base gaskets stacked under 1 cylinder?
Always learning.
www.aircooledporsches.com.au
Old 12-22-2024, 04:11 AM
I had the same thing last week, I just lightly tightened everything down then removed to double check and it was fine. Helps to have a small round magnet on a stick to pick off washers and nuts from cam towers. Not sure if it’s a common thing I don’t build a lot of motors.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 12-22-2024, 05:55 AM
E Sully's Avatar
I don't know about hammering, all mine needed was a firm push to get the o-rings for the oil return tubes seated.
Ed
1973.5 T
Old 12-22-2024, 04:12 PM
If you don’t find a smoking gun, carry on. After you torque the heads and cam towers make sure the camshaft turns nicely in its bores by hand. If it binds you definitely have an issue.
- Daniel
it's not leaking....it's just marking it's territory
Old 12-22-2024, 04:23 PM
Alan L's Avatar
May well be hanging up on one of the retun tube O rings - like Ed mentions.
That would explain the hammering down with no issues on other builds.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 12-22-2024, 05:56 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Repeating what Zuffenwerker said, once torqued down, make sure both the cams rotate freely. It doesn't take much cylinder height difference to cause binding of the cam. For the first test assembly, don't use any sealant, if the cams turn freely, remove and apply. Good luck.
1986 Targa Guards Red
2021 MT09 SP
Old 12-23-2024, 03:52 AM
