2,7 liter 1976
Flywheel-engine
Hi, allready asked the question in the technical forum,but no answer.
Can somebody help me in finding the distance flywheel-engine case for a 2,7l engine.
I m asking this while the pressure plate bolts are touching the inside transmission .when engine trans are mated.
Old 02-02-2025, 10:05 AM
Flywheel bolts are 8x 42mm with lock washer.
There are high spots behind the flywheel on the case that would catch the longer bolts.
Bruce
Old 02-02-2025, 02:23 PM
917_Langheck's Avatar
Bruce
That's the problem that the question is trying to figure out. If the hardware is as specified, where else would the problem lay? As configured the Allen head is catching the bosses in the bell housing as circled in the pic below.
Old 02-02-2025, 11:44 PM
2,7 liter 1976
If you look in the technical forum my PP is thicker than the normal ones,about 4 mm. Which would explain.Only I never heard about this issue.
Old 02-03-2025, 01:07 AM
It's a 914 ...
stownsen914's Avatar
Jimmy I just responded in the other thread. I’d measure d my pressure plate without the ring gear and you had measured with. The ring gear adds 4 mm to the stack, so I think that explains the difference.
Old 02-03-2025, 03:58 AM
2,7 liter 1976
yes , thank you.
Old 02-03-2025, 06:56 AM
Does the flywheel move in and out?
206 637 4071
Old 02-04-2025, 09:20 AM
2,7 liter 1976
How do I check that?
Prybar?
Old 02-04-2025, 10:47 PM
Prybar?
Crank runout should be only a few thousands of an inch, so a dial indicator and a small lever.
Watch here for example https://youtu.be/uXmjIrTZC6s?si=icf-YkEVsIAUNtUi
Go to the 13 minute mark.
If the flywheel moves independent of the crank, that's a different problem.
Old 02-05-2025, 11:12 PM
It's a 914 ...
For the amount of movement you are looking to explain, no dial indicator needed (and your engine is assembled, of course). A non-metal mallet and tap like John suggested in the other thread. If this is what is causing your interference, it will need to be way more than the normal few thousands of an inch of movement. More like a few mm of movement. I'd think you'd easily feel/see that much movement, if that's the cause of your issue.
Old 02-06-2025, 06:23 AM
