tailwind22's Avatar
2.7 motor low oil pressure
I have a twin plug hot rod motor in my 914 GT tribute. Less than 10,000 miles since rebuild and correct gauge and sender combo. Struggles to maintain one bar per 1000 rpm when warm. Recent leakdown showed 2% throughout the cylinders. It has a larger front oil cooler. Any thought that the extra cooler and oil line capacity might be too much for the oil pump? Trying to understand what is going on.
73 914-6 GT tribute, 2.7L twin plug
23 911 w/aero kit
07 GT3 RS Pumpkin
Old 02-05-2025, 09:50 AM
My friends call me Phish
What's the current oil weight you are using, and is this first time you noticed this after 10k miles or did just start?
Old 02-05-2025, 05:40 PM
What's the pressure @ 5K?
206 637 4071
Old 02-06-2025, 08:33 AM
tailwind22's Avatar
PO had the rebuild done and pressure has been low since my ownership a couple of years ago. Engine is running VR1 dino 20/50.
3 bar
23 911 w/aero kit
07 GT3 RS Pumpkin
Old 02-06-2025, 08:54 AM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
44 psi hot doesn’t sound too bad. What oil pump? Updated pil pressure relief valves? Bypass mod?
Old 02-06-2025, 09:53 AM
It's a 914 ...
stownsen914's Avatar
44 psi sounds a bit low, even for an early motor.
What are the oil temps? Higher temps could be a cause of lower pressure.
Old 02-06-2025, 10:07 AM
You could install the cam tower oil hose restrictor fittings to get a bit more pressure. Not a big fan, but porsche designed them....
206 637 4071
Old 02-06-2025, 06:45 PM
tailwind22's Avatar
Is the 2.7 known for lower oil pressure readings?
23 911 w/aero kit
07 GT3 RS Pumpkin
Old 02-07-2025, 09:56 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We've been moderating cam oil feed since the mid 80s. When Porsche came out with theirs in the 965 (91-92 Turbo) we investigated their version. I believe the 965 cam feed fittings are a little too restrictive.
We still make our own fitting with a slightly larger oil passage and when we encounter the Porsche version we bore them out (slightly).
The modification is a good one if you consider what your goals are.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-07-2025, 10:40 AM
