Converting early distributor question
I am having a 2 liter six built from T specs to S p/c, bigger valves , DC 30 cams etc.
Changing Marelli distributor to Bosch…..but not sure I bought the correct one (of course)
Have a Bosch 0231 159 008 ( it has 1-2-3 in it)
Thanks for expertise.
TOT
Old 02-04-2025, 11:32 AM
The shaft of the distributor changed size for 72
What you have, if it fits, use it.
Bruce
Old 02-05-2025, 04:11 AM
Dist
Thanks Bruce… dimensions look right.
May have misstated it has Petronix(? ).
There is an extensive thread going down a rabbit hole……but talks about tach working. Any issue there?
TOT
Old 02-05-2025, 06:15 AM
mskala's Avatar
The 911T distributor curve is different from the 911S/911E curve. So either get the 006 or 007, or have yours recurved. Also, not sure of what flywheel is what, but put a red line at 30 degrees if yours is 911T or 914-6 (which would have had 35 degree marking).
Mark S.
'70 914-6
Old 02-06-2025, 05:28 AM
It has a programable 1 2 3 distributor, make it whatever you want.
Old 02-06-2025, 09:09 AM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Think he corrected himself and went from 123 to Pertronix. 123 would not be old distributor with part number.
Old 02-06-2025, 09:50 AM
If you find that you need a distributor I have one out of my ‘75 that Jerry Woods just recurved. I went with a 1-2-3 after working with Icarp. I can send the specs on my Bosch if you’re interested.
Lucas
Old 02-10-2025, 01:00 AM
Distributor
Send pm.. Thanks
TOT
Old 02-10-2025, 06:31 AM
Just responded. Thanks!
Old 02-10-2025, 12:33 PM
