3D Printable Camshaft Gear Alignment Tool for Porsche Aircooled Engines – Simple, Eff
Hi everyone,
I wanted to share a useful tool for those of you working on Porsche Aircooled engines — a 3D printable camshaft gear alignment tool. It’s designed to help you align the camshaft gears accurately during engine assembly.
The tool works perfectly, but you might need to slightly file the holes to get a perfect fit, which is a quick and easy adjustment. It’s an affordable solution that gets the job done effectively.
A small piece of aluminum plate is required to complete the tool, making it both effective and economical. This will give you the precision you need without the high cost of OEM tools.
The file is available for download and printing, and I’m sharing this to help the community save time and money on their rebuilds.
You can find the file here:
https://www.printables.com/model/1269601-cam-sprocket-aligment
As always, feel free to share feedback or suggestions to improve it further. I hope this tool helps out other Porsche enthusiasts!
Old 04-18-2025, 06:34 PM
This is great, thanks.
Please describe the metal plate requirements. Is that a straight edge. Also, how is the straight edge held in place?
I see the one on the left bolts in place of the Intermediate Shaft Cover, and the right hand onto the cam sprocket?
Old 04-20-2025, 06:50 AM
Alan L's Avatar
I think it is the one and same bit - reverse sides.
But I am wondering same Qs as you. I just figured I was the only one who couldn't figure it out.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-21-2025, 02:17 PM
Alan
I think you’re correct. I see the slot on the underside of the rt image.
Old 04-22-2025, 09:01 AM
