Suspicious timing chains delivered
Hoping that some of you builders can weigh in on the timing chains I received that have seams in the rollers- very concerned about this, as my factory chains did not have any seams in the rollers.
Forum discussion: Suspicious looking IWISS timing chain delivered today...
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region Last edited by 85RedCarrera; 04-20-2025 at 06:57 AM.. |
You have 2 threads going on 2 subforums, please ask a moderator to merge them into one on this sub forum.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Yes, it was suggested that I post a pointer thread in this forum, since my original tech forum thread probably should have been started in this forum, and not in the tech forum. I have sent a request to have the threads merged.
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region |
Excellent!
And I did reply to your other post as well regarding what we found.
Well, I returned my regular timing chains with seams in the rollers, and re-ordered a set of Heavy Duty (Race) IWIS chains.
I just received them, and these chains also have seams in the rollers.. not sure what to do at this point- apparently, this is how they are being made now.
PCA Member since 1988
On the other thread you measured the lengths of you used chain and new chain. They were within .5mm total length. I would reuse the old ones.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Try not, Do or Do not
Over the years, we have been asked to rebuild engines that were relatively low mileage and chains being over $150 a pair, we invented a tool to measure the chains accurately.
That said, we still use new chains on every build. Caveat: race engines with only a few hrs don't need new chains.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I re-measured my chains against these latest new ones, and apparently my method of measuring was quite poor the first time around- I had my wife help this time. I put both chains over a straight rod, and let them hang, then pulled down on firmly both of them to measured the difference at the bottom of the chains. I got 3.5mm this time! 3.5mm x 2 = ~7mm total chain length difference. It is also interesting to note that when I place them on their sides on the bench and arch them along their sides, that they have an identical arch- no wear shows up using this technique. I used to check my motorcycle chains this way, and would always have a smaller radius on a worn chain- not so with these chains. Perhaps because they are a double chain? IDK
