-   -   New project @ Supertec (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1178828-new-project-supertec.html)
Henry Schmidt 06-17-2025 05:00 PM
The primary issue with 100mm "3.5" cylinders was the very thin cylinder spigots. These thin spigots were susceptible to side loading. 3.5 engines used a 3.2/3.3 74.4 stroke crank with very short rods which created excessive side loading.
The other issue with the 3.5, 100mm cylinders was that they were "bore in" requiring a machinist to bore the case to match the cylinder spigot. Two things were common. The case bore was too tight creating a stress at the join. Thermal expansion requires movement and if the fit is too tight, the cylinder shear at the deck.
I also saw a number of cases where the machined hole had a sharp edge (no champher) which caused the cylinders to crack when the cylinder transitioned through the heat cycle.
The cure was always pretty simple. Proper case preparation, longer rods or a shorter stroke crank with better rod length to stroke ratio.
safe 06-18-2025 02:04 AM
Originally Posted by Henry Schmidt (Post 12482703)
One side note: all the 4 valve inquiries have me thinking. Can I convert a GT3 heads fit on an air-cooled engine.
This I have been thinking about too.
But why bother with the air cooled cylinders and a fan to cool them. Why not just fit the entire GT3 engine and get all the benefits with a great crank, rods, oil pump and oil tank.
Originally Posted by Henry Schmidt (Post 12479892)
Interesting idea but blower kits have been around for years and really haven't made any significant inroads in popularity.
Do you have an opinion on why blowers hasn't been used more?
I have a plan to use a centrifugal Rotrex supercharger on my 3.6. I know its not optimal from any perspective, but its small enough to fit where the AC compressor once was and wouldn't require much modifications.
Henry Schmidt 06-18-2025 06:26 AM
Why bother is a question you could attached each and every air-cooled 911 Porsche choice. They cost too much, performance is 50 years old and parts are harder and harder to source.
Why bother? I love air-cooled 911 engines. They have been my life for 40+ years.
I don't know why super charging haven't made it on many bucket lists. There is performance there but Porsche never traveled down that Porsche and the community is pretty devoted to "what would Ferdinand Anton Ernst Porsche do".
I have a friend who is an incredible metal worker that was instrumental in a huge number of Slant Nose conversions. Although it was a factory customer option, the slant nose concept hasn't aged well. With that in mind he actually told me doing all those slant nose cars is his singular greatest regret.
safe 06-18-2025 06:50 AM
I love the air cooled engines to, I have no interest in water cooled 911's. :)
Tell him he is wrong! :) The slant nose are cool.
Immaculately restored long hoods are the norm today. I actually like an 80's conversion as long as they are in good condition, more interesting. They are getting rarer and rarer due to the restoration hype. And cars that someone put $100.000-200.000 into rarely gets used as it should be... which is a pity.
Henry Schmidt 06-18-2025 08:17 AM
He's pretty convinced his efforts were wasted....He is a true artist with metal so who am I to argue.
I could not agree more. That is why my GT3 has 83,000 miles on it. Remember I walk to work, so none of that is commuting.
My latest 80 something conversion:
Back dated 87 Carrera: 338 hp @ 6500, 301 ft/lbs of torque at 4600 on 91 octane.
3.9, Supertec ITB and Haltec , the "magic" is John Dougherty's 43X, 109 ls cams.
The ITB manifolds were cast in a friend's garage using an MFI throttle body as a pattern and Volvo Mahle pistons for the aluminum. They can work with EFI or MFI.
http://forums.pelicanparts.com/uploa...1750257180.jpg
http://forums.pelicanparts.com/uploa...1750257180.JPG
http://forums.pelicanparts.com/uploa...1750257180.JPGhttp://forums.pelicanparts.com/uploa...1750259065.JPG
Bill Verburg 06-18-2025 12:07 PM
Now , that is what I was talking about, Very nice!!
From my time w/ a 3.8 in my '76 w/ both a Mg case 915/44 and an Al case 915/67, JMO but a 915 trans needs a lot of beefing for more than a 3.6, The issue is the torque multiplication in the lower gears can misalign the cwp gears and cause, at the very least, weeping.
Besides that who needs 400hp in a 2400# package, 320 or so w/ a pouncing leopard torque curve(as opposed to a Camal shaped one) is a ball.
mikedsilva 06-19-2025 12:58 AM
I've got some old Alusil pistons if you want to turn them into a set of itbs!
safe 06-19-2025 01:37 AM
Well done!
I have a friend that has a GT3 with more than 310.000km (~200.000 miles) on it, most of them by the previous owner that traveled a lot between track days, I think that car has between 500 and 1000 laps on the Nurburg Ring.
BTW if you have any ideas why it sometimes rattles significantly on startups and can't pass emissions because of hydrocarbons in the exhaust at idle. We're thinking its the variable cam timing gear that is worn out. Pretty much everything else is replaced.
Impressive low and mid (3000-5000) on that 3.9 engine! Is that the "cam magic"?
Henry Schmidt 06-19-2025 06:01 AM
We chased that rattle in my GT3 for years and replaced everything with no improvement until we learned about the check valves in the cam housing/heads.
These little check valves are rarely discussed and are not available through Porsche.
We sourced the valves with research through an Asian car company. Kia/Hyundai ?
http://forums.pelicanparts.com/uploa...1750344995.JPG
Henry Schmidt 06-19-2025 06:09 AM
The cam "magic" was across the board but it was most noticeable in higher rpm.
The 993SS cams fell off dramatically above 4600. These DRC cams (43X 109) brought the engine to life and pulled all the way to 7K.
We're being told these cams won't work with stock Motronic but we're hoping to find something that produces similar numbers with 964/993 Motronic management.
Henry Schmidt 06-19-2025 07:48 AM
On another thread about a very cool old school build, I saw a request to use this racing upgrade on my new project.
It's a hybrid cam oiling system that incorporates center feed and spray bar technology.
The challenge would be fabricating a unique chain box cover.
The drawback of using the center feed technology was/is creating a seal between the cover and the end of the cam. Historically, this was accomplished with a spring loaded, friction contact, water pump seal. These seals generally had a very limited life span and when they fail, the engine loses oil pressure.
http://forums.pelicanparts.com/uploa...1750344031.JPG
We used a different technique to replicate the same outcome.
We gun-drilled the cam, drilled the rocker pad oiling holes and drilled & grooved the cam bearing surfaces to oil the center of the cams. With this technique there is no need to fabricate a special cam feed line or unique cover. It can be accomplished using any cam.
http://forums.pelicanparts.com/uploa...1750343356.jpg
http://forums.pelicanparts.com/uploa...1750343129.JPG
safe 06-19-2025 09:18 AM
Thank you, I Googled that part number and got a hit on eBay for $10!!
I will pass that along to my friend.
Turbo_pro 06-19-2025 10:31 AM
I find it interesting that Porsche doesn't show in PET.
Geneulm 06-20-2025 02:25 PM
The cam cover used are from 906/rsr/935. I addition to a bigger banjo bolt they have the clearance to run the oiling system. Seals are the standard centerlube items.... available but kinda pricey for something that comes in a small package!
Henry Schmidt 06-20-2025 04:00 PM
Sorry, the 906 is an animal all it's own. 906 used sand cast magnesium chain boxes and covers with seven studs.
The RSR and 935 used die cast aluminum housing with sand cast covers and 11 studs.
http://forums.pelicanparts.com/uploa...1750459602.jpg
http://forums.pelicanparts.com/uploa...1750460305.png
http://forums.pelicanparts.com/uploa...1750460305.jpg
http://forums.pelicanparts.com/uploa...1750460459.jpg
Geneulm 06-22-2025 04:54 AM
Studs makes sense. On the bride's orders to deplete stash I've sold off half a dozen sets of racing centerlube cam box covers over the last couple of years and all were mag and 70s vintage. I held on to the NOS aluminum set I'd been hoarding and used here because they were actually FLAT! None of the mag sets were. All told me the warped magnesium covers flatten out when bolted up but it just seemed like an oil leak waiting to happen.
dkirk 06-26-2025 01:53 PM
I’ve always thought a turbocharged, narrow “G” body 911 without a rear wing or ducktail would be a fun project. The challenge would be the intercooler(s). I would envision a twin turbo setup (one per cylinder bank) with each compressor feeding individual intercoolers, located to each side of the engine fan housing. No A/C nor heating system necessary here so that would add some room in the engine bay. Ducting for cooling air into the intercoolers would appear to be the biggest undertaking. For the engine, I would suggest an air-cooled 3.3 liter, prepared by Henry with all the best internal components, and boosted to produce around 500 bhp at a reasonable rpm. Externally, the car must appear as a stock, unadorned (plain) 911. What a sleeper this would be!
Henry Schmidt 06-26-2025 02:18 PM
25 years ago we built a 3.1 liter 70.4 X 97mm. It was built with 8:1 compression pistons and twin plugs. The idea was to build an engine that would run fairly well before the turbo engaged. Much like the early big port 911 SC. We chose not to use an inter-cooler to reduce turbo lag. 911 SC cams, 36 mm ports and a K27 finished off the project. The engine was put in a stock bodies 74 coupe with 7 X 8 inch wheels.
The engine product 310 hp and 265 ft/lbs of torque. The short stroke long rod engine really like to spin. We had a red line of 7400 RPM.
http://forums.pelicanparts.com/uploa...1750972491.jpg
The guy who ended up buying the car added flares, an inter-cooler and a tail.
chucksmith 06-29-2025 06:31 AM
Originally Posted by jac1976 (Post 12480106)
What seemingly started off as a genuine open discussion seems to have been a thinly veiled attempt to start fights.
for sure
Henry Schmidt 06-29-2025 09:02 AM
Originally Posted by gsxrken (Post 12481884)
Henry, you’re asking the community for their dream build (post #1) but then you layer on a set of conditions that is:
• Wild enough to excite a seasoned engine builder and attract auction buzz
• Different from anything you’ve done in 400 prior builds
• Feasible to build, tune, and sell to a wide enough market of potential buyers
That’s a hell of a Venn diagram, and the middle is pretty damn small! If you’re not trolling us (possible, especially trying to get Neal on the record) and this thing actually happens, I suspect you’re going to have to pick any 2, as the “fast/cheap/good” saying goes.
Creativity lives in small Venn diagrams.
pmax 06-29-2025 01:11 PM
How about one for your own state ?
CARB compliant EFI EFI EFI.
http://forums.pelicanparts.com/uploa...1751227896.jpg
Henry Schmidt 06-30-2025 06:37 AM
Smog compliance in California is a tough nut to crack. They even have specific catalytic converters that must be employed. For what it's worth, our goal as it pertains to smog compliance is simply to make slight improvements to stock smog engines.
We have a system to eliminate some smog systems on a few specific years but there are limits to what can happen within the laws.
Henry Schmidt 07-01-2025 08:00 AM
Starting with a stock 930 and other parts we have on the shelf.
I believe I'm leaning towards a long stroke 76.4 (993/964) crank with forged rods
97/98mm cylinders, 8.0 compression.
COP, crank fire twin plug
Single K27, small port 36mm heads, Modified CIS, DC15 cams, performance exhaust and a huge inter-cooler.
The goal is massive torque with about 400hp in a street driveable turbo.
Tonger 07-03-2025 05:00 AM
This sounds like a very interesting project - I'd love to hear your perspective on a couple of related things.
- How does the slightly longer stroke affect boost?
- How much boost do you think you need to run to achieve the performance goals?
- With the struggles of many folks with CIS and 400 hp turbos, I'm interested in following what you do to modify the stock CIS to avoid being overly rich in the midrange while still having enough fuel at redline?
- In terms of exhaust headers, would you favor equal length or shorter unequal length primaries and why?
Thanks for any insight that you can share!
metalracer 07-22-2025 08:07 AM
@Henry Schmidt: is the goal to build a one-off or create a duplicatable product?
Why not offer a baseline of engines with a couple intake and exhaust options? Use the SC/3.2 series for those seeking small displacement, high-revving performance; and the 964/993 series for a work horse 4.0. Give street guys solid and reliable performance without headaches. Make it easy to do the swap and a durable paid shipping crate to return their core to you. Make it easy for folks to get excellent engines PLEASE!
Henry Schmidt 07-23-2025 05:42 AM
Thanks for the input. Great ideas for a younger guy. We've tried doing an off the shelf (crate engine) in years passed and inevitably had to break open the engine to do exactly what the customer wanted. The challenge is guessing what the market wants.
As evidenced by this thread, there is no consensus.
The idea of crating an engine is good (that's what we do now) but if the customer has a core, it's best to have that core in advance. That's assumes the core is adequate for the build.
The idea of this thread was not to generate a new revenue stream, We are too busy already. The idea was to get my hands on a personal project mainly to keep my hands busy.
Henry Schmidt 08-07-2025 01:55 PM
Thinking out loud
First step to peanut power....
http://forums.pelicanparts.com/uploa...1754599684.JPG
PeteKz 08-07-2025 11:57 PM
With a flat top piston?
If you build an engine with the peanut chambers and twin plugs, please run the engine on one set of plugs, as well as two, and compare the difference on a dyno. In a tight chamber like that, I would expect the power difference to be significantly less than in the large open chambers with twin plugs.
Nk993 09-08-2025 02:06 AM
Camless using Voice Coil Actuators for opening and closing the valves
mikedsilva 09-08-2025 02:37 AM
I'm actually slowly gathering parts to build something similar to this for myself.
Except I'm going for 8.5:1 compression... 964 crank, 98mm barrels.
Not totally sure if I will twin plug. With low compression and relatively flattish pistons, is twin plugging still required?
My heads are the large port SC and I am using 3.2 intake manifolds with efi and cop. Cams were just going to be 964 because I have them.
The turbo i have is a Pulsar 3076.. I "think" it will be suitable for around 400hp?
Henry Schmidt 09-08-2025 06:50 AM
As we've spoken about so often here, dynamic compression is key to controlling detonation. Turbo charging an engine with 8.5:1 compression and a single plug application will require intricate analysis of cylinder pressures vs. RPM. COP suggests electronic ignition oversight hopefully with knock sensors. I have always found 964 cams to be a little lazy in CIS turbos so I generally opt for SC/Carrera cams. As to EFI tunability, I am woefully ignorant. 400 horse power is a very conservative target. Smart direction for available street gas.
mikedsilva 09-17-2025 09:34 PM
Yes. Full engine management with knock sensor is already fitted. I'm able to dial in ignition and fuel fairly accurately.
I may still opt for twin plugging... I have time.
Billiam 911 2.8 09-21-2025 04:45 PM
After years of canyon and DE driving, my 901/911 5 speed in my 1970 S with 2.8 MFI is showing signs of needing a rebuild. Are there any builders who still make modifications to make these last at high rpm use?
If this forum is strictly for engines, I will post in the 911 technical forum.
Billiam
Henry Schmidt 09-22-2025 09:48 AM
Billiam
Are you looking for advice or someone to build it.
I'm here for either option.
Billiam 911 2.8 09-22-2025 06:09 PM
Thanks Henry.
I am looking for a builder. This is beyond my skill set. What is a good time to call?]
Henry Schmidt 09-30-2025 09:06 AM
3.4 turbo
It looks like we've nailed down the project parameters.
We're going to build a 3.4 liter Turbo.
We're going to use a 74.4 crank with 53mm rod journals. The journal fillets radii were ground oversized to improve torsional rigidity. This will require the use of tapered GT3 rod bearings . That allows us to use PPM GT3 spec rods 130mm. This helps to correct the rod length to stroke ratio reduce piston side loading and increase piston dwell.
Carrera cams set at 1.4-1.7 to advance the cams of better torque at low end.
The custom X brace CP pistons were designed to produce 8.2:1 compression @ .040" deck. Measured compression may change the deck.
Heads are big valve 50/43mm and were ported to 37 x 38.
Fuel head is out to Flowtech to improve fuel volume.
The inter-cooler in a huge aftermarket picnic table.
We'll be using a K27 7200 in conjunction with an 1 5/8" stainless header system.
The ignition will be a single plug 123 with boost retard.
Standard waste gate with a .6-.9 bar spring. Less back pressure should affect how the waste gate responds.
Late 930 transmission is getting shortened to fit early chassis and a KAAZ limited slip is being installed.
The chassis/body is a replica 78/79 factory 935 destined for spirited street use.
http://forums.pelicanparts.com/uploa...1758819572.jpg
dannobee 10-01-2025 08:05 AM
That's awesome Henry!
