Oil line adapter needed
Looking for vendor to make an adapter fitting to my later oil cooler ( threaded) to my
Rubber oil cooler line to oil tank …
My rubber is for connections to stubs at both cooler and tank..
Thanks for assistance
Frank
Gold71
Old 07-10-2025, 05:10 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The threaded factory cooler is the early. Depending on the engine, not very desirable.
Something sounds kludged up but an adapter fitting can be fabricated with very little effort.
Post some pictures and Ill comment again.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-10-2025, 10:01 AM
Here are photos of connectors and hose I was proposing to use .. …I did measure both threaded ends at 32mm
Maybe just the wrong hose for these connections…
What correct hose ..
Frank
Gold71
Old 07-10-2025, 12:14 PM
Constitutional Liberal
Turbo_pro's Avatar
Part # 901 107 301 13
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 07-10-2025, 12:30 PM
Thanks Jim…
Appreciate part #
Gold71
Old 07-11-2025, 05:44 AM
