I don't use nylocks "inside" the engine.
You don’t use nyloc inside the engine, that’s what the waves washers are for
Bruce |
Curved
Things are already torqued, so I guess I just go around in order and remove, replace, retorque one by one. I have plenty of non-Nylok nuts too. |
The nuts I have on hand in quantity are:
1) Cadmium plated nyloks 2) Cadmium plated prevailing torque 3) Stainless steel As noted, #1 is not good to use inside the engine. Are either of the other two options good? Or do I need to pick up a different type for these studs of the heads-to-cam towers? |
Just use standard 8.8 8mm nuts with wavey washers.
Bruce |
I'm usually scared to use stainless hardware in/on an engine. If you ever lose or drop one in the engine, having it be magnetic can be an important advantage.
Well... we have a problem. I was putting on the chain housing on the left side, and didn't initially didn't path the chain around the big through-bolt. I realized this after torquing things down, when I went to put in the chain ramp.
Having realized this, I quickly removed the bolts, and pulled off the housing, leaving the gasket stuck to the case. I cleaned the fresh loctite off the housing, applied a new bead, and put it back into position, carefully aligning the chain this time. Grabbed fresh washers and nuts, and started going around again. But the lower inside nut didn't reach torque. It started to get tight and then... spun further. I realized it was spinning the stud along with it. Uhoh! Maybe part of the issue is how I interpreted Wayne's book "Use the factory 13mm nuts on the studs... [that] are egg-shaped locknuts that resist vibration." I used prevailing torque nuts here. I put one on and torqued it originally without issues. Then took it off to redo the chain route. Then I put a fresh one on. I did not pass the torque spec, however, it stripped before I hit the torque. So maybe I'm not to blame? Regardless, now I have a chain housing attached with a nut that can't tighten and won't back off/out either. How do I extract this stud from its stripped hole, and how do I move forward afterwards? http://forums.pelicanparts.com/uploa...1760911935.jpg I might post this in the main forum for more visibility. I'm feeling dejected after making so much progress earlier this weekend. |
See what I just wrote under your other thread. Crap happens. Welcome to the club--I'm a life member.
I believe I said previously, don’t use prevailing torque because they eat the threads on the stud
Bruce |
http://forums.pelicanparts.com/support/smileys/sad2.gif I really wish someone would just sell a kit with all the right kinds of nuts and washers. I honestly thought that was what the book intended in this particular case, but it clearly wasn't. |
Try grabbing the nut with a pair of pliers or a vise grip and pull while unscrewing. Hopefully the stud will back out.
You'll see different opinions about where to use whatever fasteners, which may explain why there isn't a "kit". For the chain boxes, personally I used plan hex nuts. I think that was factory issue, I haven't heard to use different there. |
I'll be getting to the stud in the morning, currently putting together that PP order and I need to know: do I need the special chain tensioning tool shown in Wayne's book?
I'm hoping it isn't required, although I could try to borrow one from the shop across town if needed. http://forums.pelicanparts.com/uploa...1761006211.png |
I find that very hard to believe... because that would mean the stud has stripped the thread in the case. And when I go to remove those studs from the case during my preparation, I find those studs to be VERY difficult to remove. My money would be on that nut being stripped, and not the stud. But, I've been wrong before. Whatever you do, rotate the engine so that side of the engine is towards the ground, so when you go to attempt removal of the nut, any debris does not fall into the case. And no, you do not 'need' the stomski chain tension tool. |
I would also appreciate your thoughts on if I need to acquire the chain tensioner tool. Thanks! Image hosting is broken! Here's a link: https://imgur.com/a/oSTW1Q4 https://imgur.com/a/oSTW1Q4 http://forums.pelicanparts.com/uploa...1761007087.pnghttp://forums.pelicanparts.com/uploa...1761007126.png |
Proof that I need sleep! Thank you for your help.
Its neighbor also seems to be damaged, so I suspect I should replace both. What's the preferred way to get these guys out? Double nut and push hard? Pick up a torch at HF and apply some heat first? http://forums.pelicanparts.com/uploa...1761056321.jpg http://forums.pelicanparts.com/uploa...1761056321.jpg |
double nut and heat on the case.
| All times are GMT -8. The time now is 04:10 PM. |
