The 964 cam carriers were in the mix at the 89 production run, maybe even 88.
Get the cylinder dividers powder coated and never be concerned in the future. Bruce |
If you aren't too bothered, just get some flat black paint from your autostore and have at it. Don't overthink this part of your build. Unless you are building an "instagram engine".... |
I was just saying the 964 cam carriers were in production in 89 for the 3.2 so the change was worked in pre 964 runs.
I didn’t recall in 225 postings your conversion was involved Bruce |
This is currently holding up my rebuild progress. |
We are also line boring 47mm 3 and 4 bearing housings to 49 mm to alleviate some of the sourcing issues. |
I think I paid $300 and they had to weld up some holes from sandblasting. |
The clue was when I texted pictures of the baffles on my bench he recognized the engine just by the baffles. Its costing $250 here in Milwaukee. |
Cleaning cam towers with 800 grit dremel this morning, coming out well. Pics later.
Picking up powder coat baffles tomorrow. Maybe I can put together this top stuff this weekend! |
Maybe just me, but powder coating seems over the top for tin baffles--not like anyone is gonna see them! If I need to paint/recoat mine, I'll try electro-galvanizing them. I can do that in my shop, and it's more corrosion resistant than paint.
They are usually the sort of owners that want to do it once, do it right, and have something they can share photos of with their mates; something to brag about and be proud. For a couple hundred bucks, I get all engine tins powder coated. I also get parts vapour blasted, cerakoted, zinc plated etc. Lots of stuff cannot be seen afterward. But during the process of assembly, I take hundreds of photos and progress vids for the owners. They appreciate it, write me nice testimonials and tell their friends. I agree, a lot of items won't be seen again, but it's a nice 'journey' and experience for the average owner who only wants to do it once. |
I was in the position where I needed them at least blasted, because I couldn't get the rust off myself. And once you blast it, my understanding is you need to get it coated immediately or it will flash rust.
I might have been able to get it sandblasted and then immediately paint it, but I didn't see a good way to get there. So while I wish I could have a few bucks on an invisible part, I am content. |
If you're content, that's what matters.
Mike, I get the reason you powder coat the baffles for your customers. I think gold colored zinc plating would look pretty trick too. |
Pretty baffles are back. I'm gearing up to put together the top end this weekend.
How do you all clean the inner journals of the cam towers? I can't reach my fingers down there, so the best I've managed is a cloth on the end of a stick, or the tip of a very long brush.http://forums.pelicanparts.com/uploa...1760712557.jpg http://forums.pelicanparts.com/uploa...1760712557.jpg http://forums.pelicanparts.com/uploa...1760712557.jpg |
Worked on those journals with a long brush and some twisted fingers. Now the baffles are on... hoping tomorrow morning I can get the uninterrupted time to do the headers and cam towers!
http://forums.pelicanparts.com/uploa...1760736205.jpg |
Watched some more videos to prep and saw people using "wavy washers" for the cam-to-head nuts.
I don't have any of those... do I need to get some? |
I may have missed it somewhere along the way but did your shop remove, clean, and re-install the oil spray tubes in the cam carriers? If so, be sure to verify the spray holes in the tubes are correctly oriented to spray on the rockers.
Cool pics in a second, but question first: the nuts holding the cam towers to the heads are nylock nuts, but some studs in the heads are short enough they don't emerge to fully lock into thy nylock band. Am I using washers that are too thick? The washers came in my giant "washers and gaskets" kit. The nuts I bought on McMaster Carr. Here are some pics of the ones that didn't stick out as far. http://forums.pelicanparts.com/uploa...1760800678.jpg http://forums.pelicanparts.com/uploa...1760800678.jpg That aside, here is the engine starting to look a bit like a real 911 engine again! http://forums.pelicanparts.com/uploa...1760800823.jpg http://forums.pelicanparts.com/uploa...1760800823.jpg http://forums.pelicanparts.com/uploa...1760800843.jpg http://forums.pelicanparts.com/uploa...1760800843.jpg http://forums.pelicanparts.com/uploa...1760800843.jpg |
No nylocks on the cam carrier to heads. Use standard nuts and spring/wave washers. And there should be 3 barrel nuts on each side. Total of 6 barrel nuts (901 111 271 00) and 34 standard M8x1.25mm nuts (900 076 064 02). The washers and nuts you used look like those for the valve cover gaskets.
| All times are GMT -8. The time now is 12:55 AM. |
