proffighter's Avatar
Originally Posted by Flat6pac View Post
I’ll confuse things a little more
The factory uses regular nuts and waves washers on the thermostat, breather cover.
Don’t use nyloc nuts inside the engine, use regular nuts, waves washers, locker washers on the oil pump.
Bruce
Wave washers (and others) are removed from DIN since they were found useless...
DIN 127, DIN 128 and DIN 6905
DIN 137 and DIN 6904
DIN 6797
DIN 6798
DIN 93, DIN 432 and DIN 463
DIN 526
DIN 7967
Roland
930 Turbo '81 Too many modifications to list
Old 09-29-2025, 04:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #181 (permalink)
DIN 6797
DIN 6798
DIN 526
DIN 7967
what washers do you use when fastening the cam towers to the heads?
Always learning.
www.aircooledporsches.com.au
Old 09-29-2025, 04:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #182 (permalink)
OsoMoore's Avatar
I'd like to know this too! I will go back and check my photos from disassembly.
Also, curious to the expert's opinions on disassembly/cleaning of brand new pistons and cylinders.
Do I pull the pistons out and check the ring alignment?
Do I remove the rings to clean them even more thoroughly?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 09-29-2025, 05:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #183 (permalink)
I have yet to take apart a factory built motor that had split washers or just flat washers in cam tower or inside the cam boxes.
Don’t worry about ring alignment, the rings will align in moments where they want to run.
I have always had to assemble a new set of Mahles but I’m sure they know more about P&C than we do.
Bruce
Old 09-29-2025, 05:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #184 (permalink)
OsoMoore's Avatar
Bruce
That sounds like a story. This is my first (and hopefully only) new piston/cylinder set.
Old 09-29-2025, 06:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #185 (permalink)
Looks to me like the CIS “hump” is oriented at the bottom of the cylinder and it is supposed to be on the left. You’ll need to separate the piston from the cylinder, so you can clean, oil, and orient everything at that time.
Ward Komers
1984 944 Track Car - Sold
1968 912 Rust Bucket - Under Repair
1971 911T - Under Repair
2006 Carrera S - Sold
Old 09-29-2025, 07:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #186 (permalink)
What is the weight differences from the other pistons in the set?
Casting in the piston should be 93L7 for 8.5 compression of 78/79, or what is the match number from old pistons in case they were changed?
Yes, the low face of piston goes to the right to face the spark plugs
Bruce
Old 09-29-2025, 09:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #187 (permalink)
OsoMoore's Avatar
Bruce
I have a full new set of identical pistons and cylinders, all Euro 3.0 Liter, 95.0 mm, 9.8:1, Nikasil.
I'm trying to determine if I need to remove all these pistons from their cylinders, clean, oil, borrow/buy the ring compression tool and re-assemble. Or is it OK to lubricate, properly orient the piston, and start putting them on?
Old 09-29-2025, 09:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #188 (permalink)
targa72e's Avatar
Disassemble and clean. Many have found new P&C to be quite dirty.
John
Old 09-29-2025, 10:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #189 (permalink)
You just showed one Porsche piston, so I was inquiring
By the box, you purchased directly from dealer?
Maybe that’s why they were pre assembled…
Bruce
Old 09-29-2025, 11:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #190 (permalink)
OsoMoore's Avatar
Bruce
That could be - I bought them through a local shop that helped me organize and build a full parts list, and is providing some guidance for my work.
John
Sounds like a plan. I'm pulling up videos of the process and will begin cleaning shortly. I'm looking to borrow the compression tools to put it all back together.
Old 09-29-2025, 02:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #191 (permalink)
Just go to NAPA and get the metal coil that uses 1/4 inch drive to tighten
Usually less than $10 on their tool tree.
The band with locking pliers may not have the correct band for 95mm and it has more bands than you’ll ever need or use..but the pliers are good for pulling the fan housing band together to get the bolt in.
Bruce
Old 09-29-2025, 06:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #192 (permalink)
OsoMoore's Avatar
Bruce
This thing?
Old 09-29-2025, 06:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #193 (permalink)
Yes
Old 09-30-2025, 03:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #194 (permalink)
It's a 914 ...
stownsen914's Avatar
That's what I used. As long as you are assembling your P&Cs on the bench, it works fine.
Old 09-30-2025, 05:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #195 (permalink)
OsoMoore's Avatar
Sounds good. I'm a little anxious about getting those wire circlips in - they are not normal circlips with holes. Typically this style are inserted with a pusher tool (kind of like an old cigarette lighter).
Old 09-30-2025, 07:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #196 (permalink)
It takes a lot of wrist action with needle nose pliers and getting them set.
Good option is 22 mm Stomski Racing circlip installer and a nicked screwdriver to install the clip into the tube.
Bruce
Old 09-30-2025, 08:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #197 (permalink)
OsoMoore's Avatar
Bruce
That's what I was afraid of. I'm hoping my local shop can lend me the circlip tool, especially for the mounting on the rods.
Old 09-30-2025, 08:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #198 (permalink)
I used to just push the 22mm clips in with my thumb and finish sliding it into the groove with a screwdriver. The 23mm clips caused me to get the installation tool set.
206 637 4071
Old 10-01-2025, 01:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #199 (permalink)
And way easier with the bottom row of studs out of the way
Bruce
Old 10-01-2025, 02:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #200 (permalink)
