OsoMoore's Avatar
Originally Posted by john walker's workshop View Post
I used to just push the 22mm clips in with my thumb and finish sliding it into the groove with a screwdriver. The 23mm clips caused me to get the installation tool set.
Whelp... shop lent me the ring compressor and the circlip pusher. But they need them back Friday morning.
Cylinders and pistons are ready on my bench, and I'll have to do this tomorrow.
What do you recommend as a strategy? Pistons in cylinders on the bench and install the pair at once? Or put pistons on rods first, and then slide cylinders over?
The compressors I have are a sleeve with a clasp, and a solid-piece ring with a lip.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 10-01-2025, 03:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
OsoMoore's Avatar
The black ring tool and a couple of circlip insertion tools have been amazing. The shop lent them to me and this morning in just over an hour I put one piston and cylinder completely on and prepped three more pistons and cylinders. So I'm hopeful that tonight I can get the rest of them on in about 2 hours and get the shop back their tools for the Friday work day.
Old 10-02-2025, 04:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
OsoMoore's Avatar
Successful night! Those tools are amazing.
Also, these engines are so beautiful!
Old 10-02-2025, 04:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
OsoMoore's Avatar
Getting ready to put back on the engine tins on my path to assembling heads and cam towers.
What is the recommended prep for the airflow tins? I saw some folks painting them in Cerokote, which looks fairly expensive. I also have no paint gun. Should I just clean them really well? Paint them with something else after cleaning?
Old 10-03-2025, 04:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
Paint and subassembly
Semi gloss black high temp rattle can works. This is how I do heads and cam carrier, cam and rockers.
Bruce. Double click for pictures
http://forums.pelicanparts.com/uploads26/6DF021F0_D71A_4335_AA54_B52EE2468D941538762179.jpg
http://forums.pelicanparts.com/uploads26/C4541598_71DB_4F5E_8FE8_E080B6D0E7821538762275.jpg
Old 10-03-2025, 06:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
OsoMoore's Avatar
Are you painting the exterior surfaces of the heads and such? Looking at my old parts, the only obvious paint/coat was the valve covers and I think the tins.
Old 10-03-2025, 08:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
Rattle can paint on clean cylinder dividers, don’t paint aluminum as it’s a becomes an insulator.
Bruce
Old 10-03-2025, 01:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
OsoMoore's Avatar
Bruce
Sounds good! My challenge right now is getting the dividers clean from 25 years of oily grime and a little bit of rust.
I'm considering if I need to find a way to sandblast them or such. Used an entire can of brake cleaner and they still aren't clean enough to paint.
Old 10-03-2025, 04:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
Go to the china store, harbor freight, they have little brushes with metal bristles that works well in the bend area.
Work in a bucket with a gallon of kerosene
Bruce
Old 10-03-2025, 05:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
OsoMoore's Avatar
A neighbor friend of mine in a radiator shop saw me brushing and scraping, and offered to run my baffles through the sand blaster, and strip the valve cover paint with some of their stripper stuff.
So while he works on that front, I went ahead ands started cleaning my chain housings.
I also tried to torque my oil pressure valves to 44 ft/lbs... and it feels impossible. How do you torque a wide flat-blade screw?
Old 10-04-2025, 04:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
The later replacement on Carrera are 17mm hex head, good replacement
On yours, I just Chanel lock them tight.
Bruce
Old 10-04-2025, 05:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
OsoMoore's Avatar
Any recommendation on how to clean the cam tower surface around the studs? I can get the rest pretty well with a scotchbrite pad, but I can't get good contact near the studs.
I do have a Dremel tools, but all the heads I have on hand seem to abrasive to be safe.
Old 10-07-2025, 09:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
Remove the studs...
Ward Komers
1984 944 Track Car - Sold
1968 912 Rust Bucket - Under Repair
1971 911T - Under Repair
Old 10-07-2025, 11:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
It's a 914 ...
stownsen914's Avatar
Removing studs is one option. I was able to get mine clean recently without stud removal. I found acetone and some elbow grease removed all the gasket, sealant, etc residue. I preferred to avoid abrasives, though scotch brite is probably fine. I'd avoid power tools.
Gloves and ventilation when using acetone.
Old 10-07-2025, 12:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
Counterclockwise?
Razor blade.
Rod
1986 Carrera
2001 996TT
Old 10-07-2025, 12:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #215 (permalink)
OsoMoore's Avatar
A friend helped me clean my baffles really well. Revealed a fair bit of surface rust, although structurally the pieces feel fine.
Do you think I can go ahead and paint them and use as-is? POR 15, or maybe try to grind the rust off? Or just get a new set? They are all about the same condition as these three.
Old 10-11-2025, 10:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #216 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
We pull all the studs and oil tubes, bead blast the housings and refinish all 5 sealing surfaces.
The last two pictures are a 964 cam housing converted for use on an engine with cam feed lines.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-11-2025, 11:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #217 (permalink)
Counterclockwise?
Sandblast and powdercoat /quality paint the baffles. Mine were way worse than yours and now they are like new. They are not cheap to buy used.
Rod
1986 Carrera
2001 996TT
Old 10-11-2025, 12:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #218 (permalink)
Counterclockwise?
I used a lot of razor blades and scotch brite to get my mating surfaces nice.
Rod
1986 Carrera
2001 996TT
Old 10-11-2025, 12:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #219 (permalink)
OsoMoore's Avatar
Sandblasting cleared off the rust? What did it cost you to get the blasting plus coating done?
Old 10-11-2025, 01:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #220 (permalink)
