Porsche 964 3.6 Engine crankcase value ???
I have a used crankcase and I am trying to determine a current value on it.
I dont see many for sale / selling. any advice is appreciated . ![]() Part numbers on it 964.101.111 5R 964.101.112 7R Last edited by Dak123; 08-19-2025 at 03:56 PM.. |
Try not, Do or Do not
I believe what you have is a Metzger GT3 case. I assume by the pictures that it is used so case history will be important. If it came out of a race care, it could have many (maybe too many) hours of high RPMs in it's past.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
A bit out of topic, but would a water cooled Metzger case be used with air cooled engine components?
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
Although there is a bunch of machine work required (including fabricating a fan base) and welding, if you have the money, it can be done.
I'd be interested in a ruined case for display.
That said - be careful, if anyone is thinking of making offers on the case in this thread. Not saying it is but - it's a common tactic for scammers, to post a vague question about price of a valuable item, hoping to get someone to inquire about it privately. |
I buy sell random parts as a hobby. Not a porsche guy just trying to assign a value. I find it kind of silly to assume its seen high RPMS or that its ruined
First, the engine case is from either a GT3 or a 996 Twin turbo. Because there is no outward signs of explosion and it was obviously assembled at one time, you have to question why it was disassembled. If you knew anything about the GT3 you would know that they are designed to perform at higher than average RPMs. The race engines will regularly achieve shift points above 9000. Because of the high stresses on these engines, the factory has set engine life at around 100 hrs. At that point the engine is disassembled and the parts are evaluated. If the parts are good the engine is reassembled using new items to replace normal wear parts. If it is determined that any parts are out of spec, the parts are generally disposed of. Some in the waste bin, some to builders looking to cut corners and sometimes they are sold to unsuspecting parts traders. You have no history on your engine case so when I said "history will be important" I wasn't just blowing smoke. There ends your lesson, as "silly" as it may be.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 08-17-2025 at 06:17 PM.. |
PCA Member since 1988
Schooled!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
gearhead
I find it silly to dismiss one of the top air cooled engine builders in the country when he gives you feedback. Your post is vague…
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
