Suspicious timing chains delivered
Hoping that some of you builders can weigh in on the timing chains I received that have seams in the rollers- very concerned about this, as my factory chains did not have any seams in the rollers.
Forum discussion:
Suspicious looking IWISS timing chain delivered today...
Dave
Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina"
PCA Member- Sacramento Valley region
Old 04-20-2025, 06:47 AM
Jeff Alton's Avatar
You have 2 threads going on 2 subforums, please ask a moderator to merge them into one on this sub forum.
www.turn3autosport.com
Old 04-24-2025, 06:23 PM
Yes, it was suggested that I post a pointer thread in this forum, since my original tech forum thread probably should have been started in this forum, and not in the tech forum. I have sent a request to have the threads merged.
Dave
Old 04-27-2025, 07:27 PM
Jeff Alton's Avatar
Excellent!
And I did reply to your other post as well regarding what we found.
Old 04-30-2025, 06:09 PM
Well, I returned my regular timing chains with seams in the rollers, and re-ordered a set of Heavy Duty (Race) IWIS chains.
I just received them, and these chains also have seams in the rollers.. not sure what to do at this point- apparently, this is how they are being made now.
Dave
Old 08-02-2025, 06:54 PM
PCA Member since 1988
On the other thread you measured the lengths of you used chain and new chain. They were within .5mm total length. I would reuse the old ones.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-03-2025, 12:01 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Over the years, we have been asked to rebuild engines that were relatively low mileage and chains being over $150 a pair, we invented a tool to measure the chains accurately.
That said, we still use new chains on every build.
Caveat: race engines with only a few hrs don't need new chains.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-03-2025, 07:34 AM
Hi Pete,
I re-measured my chains against these latest new ones, and apparently my method of measuring was quite poor the first time around- I had my wife help this time.
I put both chains over a straight rod, and let them hang, then pulled down on firmly both of them to measured the difference at the bottom of the chains.
I got 3.5mm this time!
3.5mm x 2 = ~7mm total chain length difference.
It is also interesting to note that when I place them on their sides on the bench and arch them along their sides, that they have an identical arch- no wear shows up using this technique. I used to check my motorcycle chains this way, and would always have a smaller radius on a worn chain- not so with these chains. Perhaps because they are a double chain? IDK
Dave
Old 08-03-2025, 12:03 PM
