2.2 to 2.7 ancillaries compatibility
I'm thinking of buying a short block 2.7 which I believe is a 1976, my present engine is a 1970 2.2 T.
I wanted to know if the engine shroud, fan assembly and tin ect. from the 2.2 are going to fit the 2.7
Thanks for any input.
Old 08-29-2025, 07:47 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Yes. Although there are slight differences (cooler air transfer, extra holes and differing wiring) for the most part, most external engine parts like perimeter tin, exhaust and cooler are interchangeable. The 76 engine cooler will not fit a 70 chassis/oil tank.
Even the clutch and flywheel will fit. The distributor will not.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-30-2025, 08:30 AM
Thanks Henry , I have a 123 distributor which they list as being good for up to 77 year will I still be able to use it ?
Old 08-30-2025, 10:46 AM
The distributor for a 2.2 case has a shaft diameter of 27mm and mounts with a steel clamp.
The 2.7 distributor has a 30mm shaft and mounts with a flange cast into the distributor body.
There is no distributor that would fit both without an adapter sleeve. 27mm ID and a 30mm OD.
Henry Schmidt
Ph: 760-728-3062
Old 08-30-2025, 11:03 AM
I see there is aluminum and stainless tubing available in the right size maybe that's a possibility .
Old 08-30-2025, 01:27 PM
PCA Member since 1988
It has to be a precise fit to prevent the distributor from wobbling in the bore. Remember that there is a groove on the distributor housing for the O-ring that seals the distributor to the bore. I'm pretty sure that would prevent using an adaptor.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-31-2025, 05:16 PM
Further research showed me the 2.7 uses a longer shaft so it looks like i wont be using the one that I have.
Old 08-31-2025, 07:34 PM
