jmz jmz is online now
jmz's Avatar
Race engine/ timing chain replacement interval?
Anyone have any thoughts on how often timing chains should be replaced on a race engine?
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 09-04-2025, 06:30 AM
Try not, Do or Do not
Henry Schmidt's Avatar
There are different chains available from IWIS but both have long life expectations.
Some of the things to look at are sprocket wear and chain tensioner type. Solid tensioners often used for reliability in racing applications will add additional chain wear.
All things considered, you should get 100 to 200 hours safely.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-04-2025, 07:38 AM
jmz's Avatar
Thank you Henry.
Old 09-04-2025, 04:29 PM
It's a 914 ...
stownsen914's Avatar
I've always assumed that chains were an automatic replacement item for every rebuild. For a race engine on, say, 40 hour rebuild intervals, would that suggest you could use the chains for 2 rebuild cycles? Probably not worth it, but had to ask.
Old 09-04-2025, 06:26 PM
Assumptions should be based in quantitative data. If the sprocket wear is minimal and solid tensioners are not employed, chains should last longer than most parts in a 911 race engine. I have never seen a broken chain and even with huge sprocket wear, the chains worked until the "stretch" hampered idler arm travel.
Henry Schmidt
Ph: 760-728-3062
Old 09-05-2025, 06:28 AM
