Trying to source a 3.2 replacement vacuum line rubber reducer
I had to remove the rubber reducer on my vacuum line on my 3.2. It was split, so I cut off the steel crimp and thought it wouldn’t be a big deal finding a suitable replacement, but everything I have looked at this far is not a good fit. The straight rubber reducer on the oil tank (pictured below next to the taller reducer I need to replace) is a fairly close match, but the larger ID is way off, and I think it would be too short anyway. Bummer Porsche only sells the reducer when you buy the whole line with it!
I can surely Frankenstein something to work, but was hoping that somebody may have already done this and found a suitable straight rubber/silicone reducer to use. Seeing as it’s for vacuum, the wall thickness needs to be relatively stout to keep it from collapsing. I could also braze a short extension with a larger OD so that I could use the oil tank reducer I bought. Any ideas appreciated! ![]() ![]() ![]() ![]()
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region Last edited by 85RedCarrera; 09-26-2025 at 05:35 PM.. Reason: To be more specific |
Constitutional Liberal
I've had problems like that on turbo installs and we cured it with an adapter sleeve made on the lathe from aluminum bar stock.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Yeah, I may have to go that route. I was hoping to find an off the shelf item. After 1.5 hours perusing vacuum fittings online, I realized that I could have fabricated it and been done already!
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region |
Slip one fuel line piece inside a larger and add some avation permatex for a seal and clamp the ends.
This might be called a 'bodge' fix....
Completely degrease the fitting inside and out. Use super glue to bond the cracked part almost instantly. Build up the outside with layers of a tough sealant when dry.. I have been using Soudal T-Rex. Let it cure completely and it shold seal well. Just not sure for how long.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
An old spark plug boot works great.
Put some heat shrink over it and heat it until the heat shrink seals the crack.... double up the heat shrink if you want as well.
Done it a few times....
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I’ll have to sift through my spark plug boots to see if I’ve got one that matches up.
The double fuel line idea sounds pretty stout. I could even put heat shrink over that. I feel stupid now for removing the crimp- I could have repaired the tear easily using any one of, or a combination of these methods I’m also liking the super glue + heat shrink idea. I could put a couple layers of heat shrink on it after. Thank you for some great ideas.
I had the same problem a while back. I ended up going down to my local NAPA and picked up a piece of 15/32 brake servo hose. The hose was supple enough that a shot of WD-40 helped it stretch over the big end without much fuss. It looks like it belongs there and is holding up fine.
John
Vacuum line
Straight from Germany and my Carrera stash
Bruce. Pm if interested
Heat shrink works great.
PCA Member since 1988
^^ That's a great idea. I've used it to repair the arm on reading glasses too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
