new nuts bolts and washers
Anyone know where to get a hardware kit (nuts, bolts, washers) for a 911 engine rebuild. I dont remember where I got them last time but really dont want to use old hardware.
Thanks, Chris 89 Carrera 3.2 |
We get most stuff from Belmetric unless its specialty hardware then we usually have the original stuff replated
Sent from my SM-S931U using Tapatalk |
I use Bolt Depot by the hundreds works for me. Just a couple things they don’t carry, I get elsewhere.
Bruce |
Try not, Do or Do not
Belmetric and McMaster-Carr are our go-to hardware sources
McMaster-Carr has higher quality and next day service, all be it at a higher priced source. https://www.mcmaster.com/ I recently encountered a shaft bearing leak in a 930 throttle body that was driving us nuts. IT took smoke to find it. It's a tiny 8mm roller bearing with a integral seal. I called my go-to bearing guy and he couldn't find in any of his books. My head mechanic did a quick internet search and found a source at McMaster-Carr. Not only did they a have a single seal bearing but they had the same bearing with seals on both ends. We ordered it at 3:00 and had three bearings the next day. I ordered three just because Murphy will bite you when you least expect it.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 12-03-2025 at 06:10 PM.. |
We stock individual assembly packages, mostly for in house use. Case assembly package, Cylinder head nut/washer package, chain housing package, timing cover package, valve cover package. We also have packages with all new studs for cylinder heads if needed.
We source from Porsche and Belmetric for most of it, and when hardware from Porsche does not come with correct finish, we strip and tumble the parts and get them plated with either Yellow Zinc or Yellow Cad depending on what the original finish is supposed to be. We also restore removed OE hardware to its correct original finish via tumbling and plating. Time consuming and not inexpensive, but its what we do. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
We used to do yellow zinc in house but The People's Republic of California makes chemical processing a regulatory nightmare.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Constitutional Liberal
I'm glad you mentioned "higher quality", because not all hardware is created equal.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
The prices are really quite low. For example, the nylok nuts I used were #90576A815. Medium-Strength Steel Nylon-Insert Locknut, Zinc Yellow-Chromate Plated, M8 x 1.25mm, 13mm Wide, 8mm High If you get the wrong metal or wrong hardness you could have issues.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
We package them this way.
Many parts are restored original pieces, coupled with new hardware. We have found Belmetric great for quality, not just on our Porsche fasteners, but for stuff for the racecars as well as oddball stuff like Black Stainless. Have used Mcmaster plenty as well in the past.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 12-05-2025 at 07:35 AM.. |
![]() Its the refinishing prep for OE hardware that takes the time in the tumblers, as you know. But, having everything organized for each assembly increases efficiency, and eliminates errors and stress tracking down that missing piece. And helps reduce chances for failure. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; Yesterday at 09:00 PM.. |
