High Temp Wire Loom or Shrink Wrap - Engine Wiring Harness
Any recommendations for a short length of high temp split wire loom?
Heat resistant tape?
Maybe just use 1.5" (3 to 1) heat shrink over the cracked area?
Thanks again you guys.
Old 12-18-2025, 08:23 AM
Raychem DR-25 is the motorsport standard. If you want the type with internal glue, Raychem SCL.
Personally, I'd slip the piece over it and install the harness before hitting it with the heat gun, for a more professional finish.
Old 12-19-2025, 07:55 AM
JoeMag's Avatar
An interesting point of note (because I hadn't looked up the specs for these before). DR-25 is 2:1 shrink and max operating temp is 302F, SCL is 3:1 with max operating temp of 230F (due to glue).
Old Today, 12:45 PM
