P Car Addict
I would like to get about 500 hp out of my Porsche. I am going to do a 3.6 conversion but have not selected an engine yet. Which engine should I go after? I am also looking to add twin turbos to the equation. What are my choices and costs on the road to getting 500 HP? Thanks
RIP Grady Clay |
Most importantly, lots of money . . .
P Car Addict
400
I need some suggestions as far as engines and a range of prices to get to that hp?
RIP Grady Clay |
Hilbilly Deluxe
A friend of mine pushes 700+ with dual turbo-converted N/A 3.6 , so i guess it's correct choice.
With other words: Dual-plugged 3.6 engine, lower C/R pistons, twin turbos, aftermarket EFI and good intercooler will do the trick. Other is using 930 engine with one big turbo, but it's going to be quite hard to drive.
Thank you for your time, |
GAFB
Get someone with rock-solid credentials to help you on this one...even with an experienced builder you're going to be paying megabucks for 500hp. Get an inexperienced builder with lots of ideas and you'll be paying for his trial-and-error...
PS, would help to know where you are located so we might be able to recommend a reputable local builder.
Several BMWs |
why 500 hp? What's your goal?
Do you want bragging rights or is there a reason you want to spend a lot of money on a lot of horsepower?
Qarl |
Author of "101 Projects"
Where do you want the power? Turbo lag will be an issue, big time if you don't run twin turbos. A twin turbo engine will run you about $20K or more...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Hi,
I'm working on the rebuild of a 956 engine with twin turbo and about 720 hp and very low lag for my 961. The price for the installation and management is about 25 K$ added to the revised base engine block. We are using a M800 ECU with additional modules to manage the valves. Here in France we do such conversions, but you also have very good engine tuners in US. regards, Luc.
Porsche 961 Le Mans'86 |
Here's another path (Renegade Hybrids) and a sample of their work:
YMMV Disclaimer: While anything is possible via the liberal application of time and/or money, I am not responsible for the foolishness of others.
Irrationally exuberant
You will probably need to consider a different transmission as well. You offer no specifics as to the car you are modifying. A 930 transmission would probably make the most sense.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Wow, 961, very impressive. For those who don't know, the 961 is the Race-Prep version of the 959...
-Wayne
Well, we work hard to rebuild it like it was in 1986 at Le Mans...
![]() Our goal is Le Mans 06
Luc:
Great story on your page about the 961! Regards, Andrew M
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
Thanks Andrew
![]() I go and see the car this week-end to check how the work is done for the chassis. I'll take more photos !
Banned
If you want over 300 HP and do not have water cooling you will be looking at a very short lived engine. Thats according to a Porsche engineer who should know. He said one big reason Porsche stopped at 300 HP with air cooled engines was that they could not get any real reliability out of them if they were over 300HP. I have personally seen 600 plus HP Porsche engines, but they all put a very pretty white coating on the exhaust pipes. The pretty white coating is the melted piston material coating the exhaust.
Navin Johnson
WTF?
Please tell us your joking about that statement. That statement is just plain misinformation. CIS turbo motors can make about 475hp with stock injection, and make it reliably as a daily driver. We have built some seriously powerful engines. In the realm of 850~900 hp. This is of course using modern engine management,The few failures we have experiecenced are not cooling related at all. The failures are component related.. The nut shears off a Turbo shaft? A cam nut backs off? Heck I get 200 hp out of my 2.2, and its dead nuts reliable..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
There's plenty of wiggle room in both arguments. Snowman's comments regarding reliability on a air-cooled production car are probably accurate - IF you think of it from Porsche's perspective. An engine that must last 100,000+ miles with little or no problems would be tough to achieve.
-Wayne
Show me any other engine with 400+hp that matches the reliability of the 930.
Rick '78 930 |
