No Expert
jgparker's Avatar
Cylinder base shim, how thick is too thick
OK, I just did the deck height check on my 2.8 project, and I've gotten some surprising results. I did the measurement with the 1mm shims my machine shop provided, and I found a 0.75 mm deck height on both sides. By my calculations, I would need 1.5mm to 1.75mm shims to get a reasonable deck height. Is this too much? Does anyone stock shims that thick? What about stacking?
Also, two questions on the book:
Chapter 5 section 4 details the deck height check after the section on ring installation. Is this order mandatory? It seems like it is much safer to do the measurement without rings, since it will need to be disassembled after the measurement anyway.
Figure 4.7 implies the two compression ring gaps should be lined-up with the wrist pin 180 degrees apart, but the text states not to line-up the gaps with wrist pin. Could you clarify which is best?
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 08-26-2003, 05:43 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I always put the oil ring gap at the top...then space the compression rings at 120deg from that gap.
In the case of a 3 part oil ring....I put the 2 scaper gaps at 10 & 2...with the compression gaps at 4 & 8.
Bob
Bob Hutson
Old 08-26-2003, 06:36 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
JP,
Just my observations from just measuring my deck heights....
You probably want to check the deck height with the rings installed. w/o the rings, the piston will have the tendany to flop around in the bore, giving you an inacurate reading, even if you are measuring on the wrist pin axis. Just be careful when sliding the cylinder off the piston to not damage the rings.
good question!!
Can't answer 'how thick is too thick', but you do need to get your deck heights a little higher.....absolute minimum is 1mm, 1.25-1.5 to be on the safe side.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 08-26-2003, 10:13 PM
Super Moderator
cstreit's Avatar
I know plenty of racers who run between .8 and 1mm, but of course this will vary depending on plug config, fuel, compression, longevity, etc..
I'm running 1.0mm, .75 is too low. because the piston can move, you may try taking the measurements at each side and averaging.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-27-2003, 10:32 AM
Author of "101 Projects"
Wayne 962's Avatar
Hmm, good point. That probably qualifies as an error, or confusing contradiction in the book. In reality, it's not really a huge deal - the important thing is that they are not all lined up. The 120-degree separation from all ring gaps would probably be fine. The rings will constantly rotate around the piston when the engine is running, so this is more like a 'best practices' type of thing...
As for your particular deck height - that does sound excessive. How much machine work was done to the heads and/or the case?
-Wayne
Deck height - checking with the ring installed does prevent the piston from rocking, although you can do the measurement without the ring, and average the amounts from a few measurements to get a semi-accurate reading.
Old 08-27-2003, 11:13 AM
Forced Induction Junkie
WERK I's Avatar
Does the 2.8 use a head gasket? Don't forget to add the head gasket to your calculations if it does.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 08-27-2003, 03:02 PM
No Expert
jgparker's Avatar
Thanks everyone.
My 2.8's are actually bored-out 2.7 Alusils, reprocessed to Nikasil, so yes, they do have a CE type head gasket, but I do not believe this adds to the stack-up since it is in a recessed grove and the head still contacts the cylinder deck.
Yes, a lot of machining was done. 0.65mm in this rebuild, and probably some more on the previous rebuild.
So, has anyone ever had to use 1.5mm of shims?
Old 08-27-2003, 04:40 PM
how much was the cylinder work?? I am thinking about getting my cylinders bored and plated with nicasil, but wondering how much it costs.. Did you have to get new pistons too, or are they interchangable??
Old 08-27-2003, 06:25 PM
No Expert
jgparker's Avatar
I don't remember how much it cost for just the reprocessing of the cylinders to Nikasil, but I'll check the invoice tonigh. I paid ~$2000 to bore to 92mm, the reprocessing, and a set of J&E pistons. My understanding is Alusil and Nikasil pistons and rings are not interchangable.
Old 08-28-2003, 06:09 AM
Wayne 962's Avatar
That's correct - Alusil and Nikasil must be kept separate.
Your cylinder shims *should* be okay - although you may have chain housing clearance problems (may have to machine the chain housings). Also, you might want to think about your chain, and whether it may be too loose (because the heads appear to have moved closer to the block).
-Wayne
Old 08-28-2003, 07:03 AM
kstylianos's Avatar
Alusil-->Nikasil replating through EBS is $150 per cylinder. The JE pistons (Nikasil compatible) are another ~$1000.
JE cut me a little deal since I bought the JE through them as well....$1800 for both the JE and the replating.
Charlie Stylianos
1982 SC Targa
Old 08-28-2003, 07:24 AM
Wayne 962's Avatar
I have a set of 3.0/3.2 cylinders on eBay right now that would make excellent candidates for replating if you don't have cores:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=33617&item=2429702431
They are also probably goog enough to be reused again.
-Wayne
Old 08-28-2003, 03:53 PM
No Expert
jgparker's Avatar
OK, EBS only sells 0.25, 0.5 and 1.0mm shims, and I couldn't find any on PP. I plan to use 1.5mm of shims. So, is it acceptable to stack?
I'm betting this will bring my deck height back close to stock, so I wouldn't be surprised if the chain housings are OK, but I'll definitely check the alignment carefully.
Thanks all,
Old 08-28-2003, 06:16 PM
Hilbilly Deluxe
emcon5's Avatar
Well, I missed the part in the text about not lining the ring gaps up with the wrist pins, and assembled mine like the picture. Oil ring gap up top, compression rings 180° out, in line with the wrist pin.
I still haven't installed the heads, so Changing them wouln't be that difficult, but I would rather not risk breaking a (not easily replaceable 98mm) ring by messing with them again.
Should I be worried?
Tom
82 911SC Coupe
GTI Cup #43
Old 08-30-2003, 11:23 AM
I missed the answer to stacking of gaskets.
Also, I assume these copper gaskets are one-time-use only, similar to copper wasshers.
Bill Leonard
Old 09-01-2003, 06:39 AM
Senior Member
Doug Zielke's Avatar
The gaskets shouldn't be reused - it's very easy to damage them. Yes, you can stack gaskets - I like to paste them together with a *very light* coat of the 574...
-Wayne
Although many rebuilders do stack the base gaskets, it is *not* advised by Porsche (Ref: Pg. 47, Porsche 911SC/Turbo 3.3 Tech. Spec. book).
Porsche offers replacement gaskets in both 0.25mm and 0.50mm thicknesses.
I found siingle base gaskets of various thicknesses are also available from parts suppliers like Worldpac.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 09-01-2003, 07:06 PM
Irrationally exuberant
ChrisBennet's Avatar
Competition Engineering also sell different thickness base gaskets.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-02-2003, 07:53 AM
