2.7 vs 2.2 mix and match question
I'm rebuilding the top end of my 2.7L. The camtowers, rockers and camshaft from my dissassembled 2.2 look to be in better condition. Is there any difference in these components. Are the camshafts the same I haven't dissambled the 2.7 heads yet to look at the camshaft part numbers.
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 10-06-2003, 04:58 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
The cam towers are the same and the rockers need to stay with the camshaft.
Which type of camshaft is it? T,E,S?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 10-06-2003, 05:16 AM
The 2.2 was a T motor and I assume the cams are a T configuration.
Steve F
69 911
71 911
87 Carrera
Old 10-06-2003, 06:23 AM
Tim Walsh's Avatar
You can put the T cams on the 2.7 but those cams are very mild. I would want to put S cams in a 2.7. Also what Pistons are on the 2.7? If they're CIS pistons you really can't run any other cams other than CIS since the valve clearance is very small.
Tim
1973 911T
2005 VW GTI
Old 10-06-2003, 07:10 AM
Tim, thanks. I do have the CIS pistons so I will use the original cams. Thanks for the input. By the way do you see any problem with installing the heat exchangers from the earlier engine. Sounds like all the books agree the 2.7 with those "burner boxes" (can't remember what they are called at the moment) didn't help in keeping the motor cool and were just a constriction.
Steve F
69 911
71 911
87 Carrera
Old 10-06-2003, 07:56 AM
Tim Walsh's Avatar
THe reactor exhaust is just a vile form of emmisions equipment. I would definitly use the early exhaust. Infact it's a common upgrade.
Tim
1973 911T
2005 VW GTI
Old 10-06-2003, 08:08 AM
Sounds like a good plan. I am also intending to use the rebuilt heads from my 2.2 since the heads seem to have the same chamber. With the 2.7 cams and the CIS pistons do you anticipate any problems with valve clearance. I cannot see any difference between the heads.
Steve F
69 911
71 911
87 Carrera
Old 10-07-2003, 06:44 AM
Tim Walsh's Avatar
The heads are the same but the 2.7 heads have a slightly wider flycut I belive to accomodate the larger cylinders. Your porsche machine shop should set them straight. You shouldn't have any clearance problems but I'd definitly test for it just in case
Tim
1973 911T
2005 VW GTI
Old 10-07-2003, 06:53 AM
